04 GTO, Predator Tuner
aandrews42
Post by aandrews42 »
I have the same exact set up with a M6 and I am getting a rich code on banks 1 and 2.
Is that normal? IT has the performance tune on it.
IBMGoat
04 GTO Tune ?
Post by IBMGoat »
Hey guys, quick question. I have an 04 GTO M6, with some mild upgrades. I recieved my Predator U7193 yesterday and installed the performance tune. I must say that I didn't notice much. Please advise if i need to make adjustments or "break-in" the tune. I also noticed that everyone is talking about logging? Thanks for your help. Here are my upgrades to consider:
SLP MAF Sensor
Trottle body Spacer
Gravana CAI
Magnaflow Cat back exhaust
Shell 93 Octane Always
IBMGoat
RE: 04 GTO Tune ?
Its the MAF...that MAF is killing you, put the stocker back on and say WOW!
IBMGoat
RE: 04 GTO Tune ?
Post by IBMGoat »
Really?? thats it? What type of gain should I expect?
oddwraith
RE: 04 GTO Tune ?
Post by oddwraith »
Probably 10-15 horsepower at the wheels in my opinion.
Slp Diablo Predator. SLP7196. 2001 Pontiac Firehawk Trans Am. Slp lid, Slp dual-dual catback.
IBMGoat
RE: 04 GTO Tune ?
Post by IBMGoat »
Well, I did the switch with the Stock MAF. And right out the gates she wanted to run, faster!! Very impressed. Seems like it pulls harder through the gears, and rides smoother. Is that all that i can squeeze out of my 5.7?
RE: 04 GTO Tune ?
no, you can get more by dumping the Shell gas too....
use mobil, exxon, sunoco, amoco or bp... or another fuel brand made by one of those companies... anything but Shell...
Shell gas tends to cause a lot of KR...
IBMGoat
RE: 04 GTO Tune ?
Post by IBMGoat »
ok, What about all this talk that the car needs to learn the tune? or logging?
RE: 04 GTO Tune ?
IBMGoat
RE: 04 GTO Tune ?
Post by IBMGoat »
Thanks, sounds good. I will check it out.
JDGTO
Problem with dslogredux
Post by JDGTO »
dslogredux does not read all of my log it gives me the message unhandled exception and I did log absolute throttle position but Im running Vista 64 any help would be appreciated
I have a 7193, 04 GTO A4
I finally had time to check log and run another one hope you can help because I got the same error message with this 2nd log
concoursd
RE: Problem with dslogredux
Post by concoursd »
pm 06montess as he is the dslogredux guy. hell get you straightened out.
please post up your log file, and I'll take a look at it....
Grumpy_Aero_Guy
Post by Grumpy_Aero_Guy »
Uninstall DsLogRedux
Uinstall .Net Framework
Reinstall .Nt Framework as administrator
Reinstall DSLogRedux as administrator
DSLogRedux.com
Ill_Born_SS
Post by Ill_Born_SS »
Excellent advice !
PS. Don`t forget to re-boot after the uninstall and again after the install.
" Just Friggin Wicked"
Now with TCM support...
