vararam intake??
vararam intake??
anyone running a vararam intake.? i seen the website and they said they worked with different tuners. how are they?
RE: vararam intake??
I'm not running one, but know truck and vette guys that do, and they work very well...
Thats cool i seen there site saying it adds like 25-50 hp depending on the programmer u seen any logs from one as far as the ltft adjustments??
yeah, get's you a lot more air... leans ya out....
the truck I just did this weekend, his ltft's went up to +8....
so slope adjustments will be necessary...
I have the vara-ram on my 07 Yukon Denali. It makes the 6.2 pull forever on the topend. Idle quality goes up also. I haven't tuned it yet, but the rumors that the 6.2 will relearn seem to be true, because the truck keeps running better and better the longer it's on there. Still going to put the predator on the Denali though...
Truck also went from 14.2 MPG's to 15.7 MPG's after I installed the intake.
1967 C10 Prostreet, 502 and a Glide,
2007 KAW ZX-14, too fast for you. 8.9 @ 153mph
2007 Yukon Denali
2007 Yukon Denali
I'll put up a video or pics tommorrow.gump2388 wrote:i bet u wouldnt throw some pics online would u. i know i can go to there site and see it but i wanna see what it looks like from the front if it can be seen. thanks
2007 Yukon Denali
2007 Yukon Denali
Dannenbergcorvette
As a vette guy I have always been concerned about sucking up water as I speed down the hammer lane. If you guys don't have that concern - I have heard that the Vararam is an awesome system.
Let me know what you think.
Dannenbergcorvette
Dannenbergcorvette
2001 C5 K&N Twin Tube Air Intake, BBK Throttle Body, Corsa X-Pipe, Corsa Pace Car Exhaust, Predator Tune
They offer a drain off upgrade for that purpose. On the truck system's you don't have to worry about that. Unless your in 4' of water. You don't have to worry about the 5" ducts sucking about any water.Dannenbergcorvette wrote:As a vette guy I have always been concerned about sucking up water as I speed down the hammer lane. If you guys don't have that concern - I have heard that the Vararam is an awesome system.
Dannenbergcorvette
2007 Yukon Denali
2007 Yukon Denali
WhiteBuffalo
The Volant Ram scoop leaned me out +7 which I measured on the predator after driving over 70 miles.
Dialed it in and things run fine...
I worry about the water also......I notice I get water spots in the CAI box but none in the intake pipe to the throttle body.
I checked the Vararam site and found it interesting they stated one of their systems offers improvements by moving the maf closer to the throttle body.....
Interesting..
Interesting..
Thats the intake that I am running. It sets the truck up just like the vette. There is maybe an inch between the MAF and the TB. Sounds awesome when the twin snorkels start sucking at WOT.WhiteBuffalo wrote:The Volant Ram scoop leaned me out +7 which I measured on the predator after driving over 70 miles.
Interesting..
2007 Yukon Denali
2007 Yukon Denali
WhiteBuffalo
I guess if the MAF is closer to the throttle body it is metering air right at the throttle body so it must be more accurate......Midevil1 wrote:Thats the intake that I am running. It sets the truck up just like the vette. There is maybe an inch between the MAF and the TB. Sounds awesome when the twin snorkels start sucking at WOT.WhiteBuffalo wrote:The Volant Ram scoop leaned me out +7 which I measured on the predator after driving over 70 miles.
Interesting..
HMMMM...I just wonder if I move mine on the Volant setup if it would gain me anything?? I just struggle a little bit since it would be closer to the engine and the heat could throw off the readings of the heating elements in the MAF.... HMMM
