2001 Lightning Steeda pulley question
01lightning
Post by 01lightning »
I am going to purchase a Steeda 8.4 pulley for my supercharger with the diablosport tuner they offer. What download do I need if all mods are as follows: Steeda high flow cold air intake kit, 8.40 pulley with new belt. The rest of the engine and power train is stock.
LightningMike03
Post by LightningMike03 »
Assuming you are using the U7158 and 93 octane gas is available, you should use that tune.
I would STRONGLY suggest you get a good Wideband A/F gauge and install it before making any modifications to the Lightning.
I've been using the 93 octane tune and I'm currently running a 2.7" upper and 9.0" lower pulley. Getting more than 17LBS boost and the A/F is dead-on 11.5 while under heavy load.
I would also suggest you run a 1-2 step colder spark plug. Either the NGK TR-6 (1 step) or the Denso 22 (2 step).
Good call Mike....thanks
Return to “General Questions”
