updated my 2005 magnum r.t now it has a miss in engine
jmdi
Post by jmdi »
u7135 v.9r16 2005 dodge magnum r/t
it tried to update my car and when i did now it has a miss in the engine and set the engine light on. the code was for downstream air injeter did i recalibrate the pcm wrong??
jmdi
RE: updated my 2005 magnum r.t now it has a miss in engine
Post by jmdi »
someone please help me
Whats the exact code number? Nothing the Predator does should cause a miss, so most likely you already had a problem and the Predators tuning simply made it more obvious.
jmdi
Post by jmdi »
i did not write code down today i will get it i think its the o2 sensor but id like to know if i screwed up updateing my pcm on my car
jmdi
Post by jmdi »
ok i just got the code it is p1411 secondary air injector incorrect downstream flow can you help me??
Ahhh...the famous cylinder reactivation codes.
Disconnect the battery, let it sit for a few, then reconnect, all will be well.
Return to “General Questions”
