How much power from the 6.2L?
Midevil1
Post by Midevil1 »
OK. Someone give me an honest answer. I am about to either order another PREDATOR or get a HP tune down at FASTLANE today. I need to know how much of a power increase will I get from the 93 tune? How much in a % will it remove of the TQ management? And when will tranny manipulation be available?
I already installed the vara-ram cia, magnaflow cat-back, msd wires and 180T. I am planning on adding LT's. I have 24's on the truck. Will the Predator compensate for this size wheel? GM doesn't have a program for 24's so I am stuck with their 22" program right now.
Thanks for any replys.
1967 C10 Prostreet, 502 and a Glide,
2007 KAW ZX-14, too fast for you. 8.9 @ 153mph
2007 Yukon Denali
RE: How much power from the 6.2L?
The Predator will add a solid 20+ rwhp on 93 octane, and remove most of the TM on the PCM side.
It will also allow you to correct for larger wheels/tires no problem.
Midevil1
Re: RE: How much power from the 6.2L?
Post by Midevil1 »
mikel wrote:The Predator will add a solid 20+ rwhp on 93 octane, and remove most of the TM on the PCM side.
I won't have the problems with the 7194 that the 6.0L guys are having.? I already checked my vin. and its supported.
2007 Yukon Denali
gump2388
RE: Re: RE: How much power from the 6.2L?
Post by gump2388 »
nope as they have a way around it now. no problems for the 7194 anymore.
