2001 Lightning Steeda pulley question
01lightning
I am going to purchase a Steeda 8.4 pulley for my supercharger with the diablosport tuner they offer. What download do I need if all mods are as follows: Steeda high flow cold air intake kit, 8.40 pulley with new belt. The rest of the engine and power train is stock.
LightningMike03
Assuming you are using the U7158 and 93 octane gas is available, you should use that tune.
I would STRONGLY suggest you get a good Wideband A/F gauge and install it before making any modifications to the Lightning.
I've been using the 93 octane tune and I'm currently running a 2.7" upper and 9.0" lower pulley. Getting more than 17LBS boost and the A/F is dead-on 11.5 while under heavy load.
I would also suggest you run a 1-2 step colder spark plug. Either the NGK TR-6 (1 step) or the Denso 22 (2 step).
Good call Mike....thanks
