U7137 beta update
HoustonHemi
Post by HoustonHemi »
Did you make the upshifts softer in the 9t03c vs the 93 canned tune that came on the predator? With the 91 and the 93 canned tunes my 07 would chirp the tires every time going into second. Now with the 9t03c it shifts softer. Not that this is a bad thing but was just curious if you made the shifts less harsh. My truck is also staying in 3rd gear when it should downshift into second. Other than that everything is great. Getting 19+ mpg at 67mph with mds turned off with 4.56 gears.
montstr
Loaded u7137-9t03c tonight
Post by montstr »
The shifts definitely seem better, more responsive. I don't know if I didn't give the truck long enough to "learn" the new tune, but there seemed to be a lot of spark knock after updating with 9t03c with the 93 octane tune. I had been running for months with 93 octane tune and fuel and hadn't noticed this. I bumpred it down to the 91octane tune and it seemed to go away.
I will run it for a while on the 91 octane tune and bump it up again next time I fill up and try to get a log to see if there really is any knock.
Safe to assume no change to timing with this tune?
Thanks!
Montstr
2008 Ram 1500 QC
Volant CAI
Flowmaster Exhaust
Diablosport 93 Octane Tune
HoustonHemi
HoustonHemi wrote:Did you make the upshifts softer in the 9t03c vs the 93 canned tune that came on the predator? With the 91 and the 93 canned tunes my 07 would chirp the tires every time going into second. Now with the 9t03c it shifts softer. Not that this is a bad thing but was just curious if you made the shifts less harsh. My truck is also staying in 3rd gear when it should downshift into second. Other than that everything is great. Getting 19+ mpg at 67mph with mds turned off with 4.56 gears.
I take that back. I guess i was beating on my truck alot yesterday tires got warm and so did my engine probably. Still chirps the tires. I think you have the part throttle and full throttle upshifts dead on.
johan
Post by johan »
We did not change the timing in the 03c vs r02 tunes.
You do have to let the transmission learn for a bit for the full effect of the changes we did in the tcm tuning.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
need-a-cage
Post by need-a-cage »
johan wrote:Yes it interpolates from 0% tp to 45% tp.
I knew it! Thanks. This will allow me to really dial it in. Cool stuff! I am Happy Now!
06 QC SLT Big Horn Hemi 2wd 20's,3.92's, Magnaflow, custom Y, Diablo, Edelbrock Shorties, modified K&N CAI.
14.64 @ 90.5 mph (short belt, no spare)
93 Stroked and Blown Mustang
10.84 @ 128.5mph
need-a-cage
DiabloFan wrote:We still need better downshifting. It sucks having to lay into it to get it into the right gear.
Not if you have an 05 or an 06, you just have to adjust it.
Adjust your 3-2 downshift rpm at 45% to at least 3k and it will make a huge difference. I am going to move it up to 3.5k or 4k and try that. Make sure that you move the 55% and the other one more too.
10.84 @ 128.5mph
lumpy69
RE: U7137 beta update
Post by lumpy69 »
got the beta file this aft & installed. WOW
seems to have more power & Shifts much firmer.
so far looks real good ,will report back after I get a few
miles on it.
HoustonHemi
My 07 seems to jerk forwards when i put it into drive. It did the exact same thing stock tune when u first started it and the idle was still somewhat high. But if it had idled down to normal it would not. With the latest tune installed it will jerk forwards HALF of the time when putting it into D from R no matter how long it has been idleing.
Harmwalker
Post by Harmwalker »
HoustonHemi wrote:My 07 seems to jerk forwards when i put it into drive. It did the exact same thing stock tune when u first started it and the idle was still somewhat high. But if it had idled down to normal it would not. With the latest tune installed it will jerk forwards HALF of the time when putting it into D from R no matter how long it has been idleing.
If you shift into from D into neutral for just a sec and then put it in R, it might help.
2007 Ram 1500 QCSB 4x4 5.7L HEMI Pearl Black
Magnaflow Dual Cat-Back Exhaust
Diablo 91oct Tune
Big Vararam CAI
Poweraid TBS
Wife's Ride - 2008 Charger SXT AWD 3.5L HO 24-Valve V6 - TorRed
lumpy69
Post by lumpy69 »
day 2 with U7137 beta update and all is performing great.
very happy so far,no blips yet.
2004 Ram 1500 4x4
3" lift in front
1.5" in rear
cold air intake
315/70/17 Mudders
Diablo U7137
MBRP Cat Back Duals
456 Gears
DiabloFan
Post by DiabloFan »
Mine is a little jerky going into r after I start it. Has anyone else notice the starting rpm is a little higher than normal?
pittchallenger
Post by pittchallenger »
I am new at this what is wot?
lumpy69
Post by lumpy69 »
Day 4 and the only blip is the cruise control shuts itself off @ 70 mph.
2004 Ram 1500 4x4
3" lift in front
1.5" in rear
cold air intake
315/70/17 Mudders
Diablo U7137
MBRP Cat Back Duals
456 Gears
crhemiram03
Post by crhemiram03 »
i have the same problem lumpy but mine started with the initial instal of the predator it start turning of at 65 and now its 69. and PITTCHALLENGER wot is wide open throttle
HoustonHemi
My cruise control seems to work at all the speeds it did stock in my 07.
