Steeda CAI + Mustang GT 07
Landario
Post by Landario »
Hello,
right now i use a Steeda CAI in my Mustang GT 07(MT).
The Dealer installed the Steeda 91 Octane Tune.
So far i don't see any real difference between this tune and the stock settings other than i have to use 91 Octane Fuel now.
The Predator is updated to the latest Firmware.
Now i ask myself if i can use some of the Diablosport Tunes instead of the Steeda 91 Ocatane Tune to get some better results. Or should i reinstall the Steeda 91 Octane Tune(maybe it was updated with the latest Firmware ?? ) or would this be a bad idea.
Thanks for some advice.
Best regards
Chris
Re: Steeda CAI + Mustang GT 07
Landario wrote:Hello,
Best regards
Chris
When running the Steeda CAI, you must use a tune that was specifically designed for that kit. Using the Diablo tunes would cause the car to run poorly and be dangerously lean.
Landario
Post by Landario »
Hi Mike,
thank you for your reply.
Are there other Tunes than the 91 Octane Tune included in the Predator for the Steeda CAI ?
Best regards
Chris
No, currently we only had room to add 91 octane versions of these tunes. If you would like to make a 93 tune, use the global timing parameter to add 5% to the timing curve.
Mike
Return to “Predator Ford Gas”
