Mustang V6 - 3.73 gears
titleistmover
Post by titleistmover »
My 2007 Mustang V6 has an Airaid Cold Air Intake, Magnaflow Cat Back Dual pipes and a Diablosport High Performance (Firm shift) tune. If I swap out the gears with 3.73's, will that effect my tune?
Mustang 2007 017.jpg (67.89 KiB) Viewed 1364 times
Phil
RE: Mustang V6 - 3.73 gears
Post by Phil »
It won't effect your tune just your speedo reading correctly. But lucky for you the predator will allow you to make the gear swap change so your speedo will read correctly. One of the benefits of owning a predator.
Phil Jones
Diablosport Inc.
Tech Support
Please do not PM us for tech support, post up first!!!
titleistmover
Will the speedo typically read faster or slower?
Vas@Diablosport
Post by Vas@Diablosport »
When you install larger gears than stock, the speedo will read that you are going faster than you actually are.
No, i don't work here.
Return to “Predator Ford Gas”
