Hi,
Here's my friend setup:
Stage2 PCM, Stage 2 injectors, stage 2 tip sensor Map sensor.
Stage 3 Manifold & turbo, Stage 3 wastegate, stage 3 fuel rail and pump.
Everything is installed but not running fine.. Probably because of the stage 2 PCM. We have a local speed shop who will be authorized diablosport tuner soon! If he buy a predator will he be able to get a tune on his stage 2 PCM from that shop? Or he really need to buy a stage 3 PCM.
Same thing for me! I bought: stage 2 injectors, Tips and Map, kinetic wastegate but I don't have the Stage 2 PCM... Do I really need to buy it or they will be able to tune the car with my predator?
Or can I put the Diablosport stage 2 map into my stock pcm? Or you really need a stage 2 PCM to put that map in!?
Thanks!
Stage 3 without PCM
Stage 3 without PCM
RE: Re: Stage 3 without PCM
Custom tuning will allow you to run any combo of parts as long as the tuner understands what needs to be changed.
Thanks!
Do I really need to have a stage 2 PCM to put the stage 2 map?
Or I can use my stock PCM and with the stage 2 map it will do the same thing as a DS stage2?
(MAP TIP 3 bar, stg2 inj, kinetic wastegate)
Like I said, with proper tuning you can run any combo of parts with any PCM.
