ABS
lawnmoman
ABS
Post by lawnmoman »
I have an 07 Ram Hemi. I have what i consider a major issue. Last week i had to avoid an accident by braking. It seems that even if an ABS light does not come on, it does not mean it is working. I have 3 out of 4 tires (2 weeks old i might add) flat spotted. You see when you load a tune apparently ABS is deactivated without you knowing it. I would like to speak to a representative about this.
brandy16
RE: ABS
Post by brandy16 »
ABS is not deactivated when you load a tune. It works fine on my 2006 300C. I have an 02 dakota that is only ABS on the rear brakes and it dose what you discribed when I brake hard on pavment no tune loaded.
lawnmoman
RE: ABS
Post by lawnmoman »
u7137!
4 wheel anti lock.
johan
RE: ABS
Post by johan »
Yeah we by no means touch the ABS module.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
lawnmoman
RE: ABS
Post by lawnmoman »
so the posts i see about abs light and non-function aren't there?
RE: ABS
If you have not already, please make sure your Predator is up to date on the 9r03 revision.
Mike
Whoa
RE: ABS
Post by Whoa »
I don't know should this be some what of a concern? I have an 03 ram hemi and after I loaded the tune my abs light and brake light stayed on until I put my truck into drive and then back into park.
Quick
Re: RE: ABS
Post by Quick »
lawnmoman wrote:so the posts i see about abs light and non-function aren't there?
First you have to read the posts carefully. Some people are turning off ESP completely with the Predator selecting what is now called "dyno mode". After that some people are having some problem with their ABS light staying on (various things that I think were due to some combination of selections but I haven't paid attention). You are the first that I know of to say that your ABS did not work AND the light was not on. Have you tried putting it back to stock and recreating the stop you made to see if you get the same effect?
ABS is pretty much separate from ESP/traction control. The tunes reduce torque management which in turn reduces ESP. As far as I know they do not touch ABS.
2006 Magnum SRT8
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
Black05Hemi
RE: Re: RE: ABS
Post by Black05Hemi »
There have been a few cases of people using the U7137, loading a tune, and the ABS light stays on...I have not seen Diablo specifically address these concerns for some reason
Quick
RE: Re: RE: ABS
Post by Quick »
I thought they went to a different version CROM and it resolved it? In any event, that's VERY different from ABS not working and the light NOT being on.
2006 Magnum SRT8
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
Re: RE: Re: RE: ABS
Black05Hemi wrote:There have been a few cases of people using the U7137, loading a tune, and the ABS light stays on...I have not seen Diablo specifically address these concerns for some reason
We've certainly dealt with it, and in fact made sure as of 9r03 no such thing will happen.
I did not notice if you said you were on the latest revision yet?
lawnmoman
RE: Re: RE: Re: RE: ABS
Post by lawnmoman »
Ill try to answer all.
I have not duplicated nor do i want to on dry pavement. As i said these tires were new. I will have them shaved next week.
i have the 9r02 crom.
I will play around with rain this weekend (fingers crossed).
Try tuned and not to check when where and how.
then will load 9r03.
lawnmoman
Post by lawnmoman »
Sorry fro the broken english im using this crappy phone.
Black05Hemi
Fair enough Mikel...And, yes, i've been on the latest revision, ever since johan released the beta...
chuck300z
Post by chuck300z »
I have latest update and still have problem with ABS / Brake light. Diablo needs to get this problem fixed
