Predator U7140 05-06 Mustang Update
kmac1
Post by kmac1 »
Guys, there is a new update located here: http://www.diablosport.com/index.php?mo ... lay&pid=11
This update was to add the new 2006 calibration updates and a few more Cold air kits. It's been up for a week now, just a reminder for those who didn't know.
The following Cold air intakes are now supported for V8 GT's:
80mm WMS
85mm Ford Racing Bullitt
90mm Ford Racing
AirAid (insert removed)
JLT
K&N
Roush
S&B
StreetSmart
Steeda
and we also included two more new ones, an 85mm and a 95mm for some universal applications out there that need support.
For the V6's we now support the following Cold Air kits:
AirAid
JLT
K&N
Roush
S&B
Steeda
as well as a universal 85mm tune...
Enjoy!
Kevin@Diablo
Lampoon
RE: Predator U7140 05-06 Mustang Update
Post by Lampoon »
What happened to the C&L street w/93?
http://www.diablosport.com/index.php?na ... ic&t=11860
speedracer
Post by speedracer »
What about a tune for the AEM?
tuningss
Re: RE: Predator U7140 05-06 Mustang Update
Post by tuningss »
speedracer wrote:What about a tune for the AEM?
Use the 85mm universal tune. That should work fine.
http://www.tpctuning.com
lordscorpion
K&N CAI Tune?
Post by lordscorpion »
On my 2005 Mustang GT, if the K&N CAI doesn't require a tune by default, what does this tune "do" per se?
I have the K&N CAI and want to remove the hydrocarbon trap to make it less restrictive. Will this tune address that?
cpiefer
RE: K&N CAI Tune?
Post by cpiefer »
I am planning on running an airaid cold air system and filter and their spacer as well, would this be the tune for me??? I am new to this and looking for advice.
cpiefer
RE: K&N CAI Tune?
Post by cpiefer »
That link took me to the download page I have been looking at already and I think I already have that version in my diablosport correct? My tuner says it is 9r03
RE: K&N CAI Tune?
Yes, 9r03 is the latest.
cpiefer
RE: K&N CAI Tune?
Post by cpiefer »
I am just checking that once I go to the car and plug in I should be all set then? Will I have to set anything for the Airaid or ???
RE: K&N CAI Tune?
Yes, it will have an airaid tune.
lordscorpion
K&N CAI?
Ok, I'll try again.
What does the K&N CAI tune do if the out of the box intake does not require a tune?
cpiefer
RE: K&N CAI?
Post by cpiefer »
Thank you for your resonses, I wasn't sure of how this worked as it was my first time doing something like this. Let me say this, the difference after installing the Airaid cold air system then doing the DiabloSport 93 oct Airaid firm shift setting is unreal.
Now to comment onlordscorpions reply,
Once I had my cold air installed but not tuned I started the engine just to see if everything seemed ok and it ran pretty rough. I then hooked up and installed the tune and now it is perfect. I do know that the ford system comes with a calibrater and after talking to a service tech friend of mine at ford, you need a tune with more air. I also did not use the restricter tube that came with the system.
drksthr
Post by drksthr »
is the C&L intake tune no longer available for the v6 with the new update?
lordscorpion
Does the K&N tune require 91 octane???
What about the AirRaid (no insert) tune, does it require 91 octance as well?
autodiag
Post by autodiag »
Yes, I am curious about the ocatne as well on the K&N program specifically. You say in some posts that it is for 91 octane, but when you actually load the program, it says "requires 93 octane". Which is correct? I am putting this in a customer's car and he is about to drive away. Is it going to detonate on him?
Mike
Return to “Predator Ford Gas”
