My Predator won't load on my pickup, it says backup not saved, I did remove my old tuner which was a SCT LIVEWIRE JUNK!!!!!, but now the predator wont load in my pickup. Version is the one you just sent me 7r19dz and the stragety is VRAA7S8. I don't know if you can help me or if I need to have dealership reflash the computer.
Brent Kulp
Won,t Load on my pickup but loads fine on others.
- strokethis
Its not what you buy, it what you build.
predator programmer,adjustable HPOP module, Overboost eliminator, intake, 5 inch exhaust, banks wheel, built trans, manual lockup switch, 315's and 100hp sticks. 400hp and 900ft lbs to the ground.
RE: Won,t Load on my pickup but loads fine on others.
Try going in to the tool and select options/troubleshooting/verification, set it to OFF, then try to instal the tune again.
Be SURE to remove the tool from the other truck before attempting to install it in yours.
- strokethis
Thanks for the fast response, I will try this tonight, also I do some tractor pulling with my pickup, what does it take to do some custome tuning to work with some 100hp injectors.
Brent Kulp
Brent Kulp
