2009 Supercharged Challenger
- davenportmotorsports
I would like to know which table I should adjust to add timing while in a boost condition. I am starting with a base supercharged tune, but would like to tweak it. I have tried adding some of the tables, but my scanner still shows the same timing.
RE: 2009 Supercharged Challenger
Main one is the WOT spark table, make sure to check the map scaling and see if it has been changed then log at what map the vehicle is at where you want to change it, then change the values in those areas.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Diablosport INC
