300 srt/ Knocking/Pinging
Rick184u
RE: some knock issue
Post by Rick184u »
also srt8 t try getting a 180° Low-Temperature Thermostat for your 6.1 or 5.7 you can get them here they are very cheap i get all my parts from here its a bad ass wed site http://www.rpmoutlet.com/rpmcstat.htm enjoy!
SRT8_T
Post by SRT8_T »
yea i got one in there.. thanks rick
fordomatic69
RE: 300 srt/ Knocking/Pinging
Post by fordomatic69 »
Always expect to see some ST Knock Retard just before a shift (especially gear 1-2 and 2-3). This is false knock that is being picked up by the sensors but as long as it drops back down to 0, then back up just before the next gear change, it' fine. Like Quick says, if you mash the throttle in 4th or 5th while cruising, you'll get some knock too. The 6.1's are a little more sensitive to it than the 5.7's so you may expect to see 3-4 degrees during the false knock. 5* may be a hair too high but if you can get it down to 3 just before shifts, you're dialed in pretty good without a wideband.
Fordomatic Says:
"I've heard of Vaporware... but I've never actually seen it" :lol:
http://www.twincamlubricants.com - For all your synthetic lubricant needs. Order Online and save over retail.
