Sierra 2008 5.3L I need your help and Reccumendation
08Sierra5.3L
HI,
My car is Sierra 2008 SLE 5.3L
I am usin Octain 91
First time I heared about Diablosport when I went to remove the speed limit in my car, the seller show me the Diablosport device U7194 which matches to my car.
I made a search about it and the best place to ask people about my Questions is HERE.
I will list some Question that will help me to buy the U7194
1-What is the best Package should I buy with the U7194?With USB cable or any recumanded parts?
2-How many times can I install & Uninstall the the tunner?I heard its 3 times then I have to pay money?
3-I will add an K&N Air Intake and magnaflow kitback. What should I do after installing the new parts with U1794? (Is there an option to programe the car to include Air Intake)?
4-Could I help My friend who has Tahoe 2008 to upgrade his car too?
5-Is it possible to sell it to other person to upgrade his car In case I sold my car?
how to install the updated tuner
the final and biggest Question.
IS THE DIABLOSPORT BETTER THAT DYNO PROGRAMING.
I am usin Octain 91
My Car:
Sierra
2008
SLE
Stealth Gray
Sierra
2008
SLE
Stealth Gray
RE: Sierra 2008 5.3L I need your help and Reccumendation
1 - buy the pc interface kit as well, which includes the power adapter and serial/usb cable. this will enable you to connect to your pc to be able to update the predator to new revisions, download data logs, import/export tune files, etc.
2 - as many as you want... dunno where you heard "3, then you have to pay money" - as that is not true at all... once you buy the predator, you can use it to make adjustments and install tunes to your vehicle as many times as you want - there is no limit.
3 - after installing those items and the tune, put on about 75 miles to let the new amount of airflow and fuel trims get relearned by the ECM, then do some data logs to see what your average ltft's are reading. then adjust your injector slope accordingly so that you get your average ltft's in the 0 to -2 range. here's info on how to do all that correctly: http://diablosport.com/index.php?name=P ... opic&t=917
4 - no, you can only use the predator on one vehicle at a time. once you install a tune to your vehicle, it is LOCKED to your vehicle, and can not be used on another one. your friend needs to buy his own.
5 - if you sell your car, you will need to restore the original backup tune to it first, so that you don't sell it with the tune still installed, and also - by restoring the original backup to the car, that will unlock the predator from it so that it can be used on another supported vehicle. THEN you could sell it.
08Sierra5.3L
its very clear Mr.06MonteSS
while searching in ebay about predator i found one seller wrote this
Tunes
93 Octane Performance Tune
91 Octane Performance Tune, Corvette Only
87 Octane Performance Tune, Truck & SUV only
Modify Factory Tune
Personally I use Octain 91, in this case I`ll not find a ready to install Tune for 91octain which matchs my car
your advice please
Tunes
Modify Factory Tune
your advice please
My Car:
Sierra
2008
SLE
Stealth Gray
Sierra
2008
SLE
Stealth Gray
yes you will... the 7194 predator for the trucks will have three tunes on it... a Diablo performance tune, an 87 octane tune, and the Modify Factory Tune (or called Factory HP Tune)...
the Diablo Tune is made for 91 octane gas... that's the one you'll want to install and use.
08Sierra5.3L
what are the three Tunesthe 7194 predator for the trucks will have three tunes on it
the ebay seller mentioned 91 for corvette only!!!!
do you mean a Diablo performance tunethe Diablo Tune is made for 91 octane gas
last thing
how easy can I adjust it if I add the K&N AirIntake
would it take long time and should I make the log you mensioned in http://diablosport.com/index.php?name=P ... opic&t=917
and what does Diablo Performance tune include
is limited remover included
is editing petrol mixing included
and list some if you know
sorry for the long questions I asked But it seems you are very active in here and I saw you replies in all topics
thanks in advance
My Car:
Sierra
2008
SLE
Stealth Gray
Sierra
2008
SLE
Stealth Gray
they are just that - for corvettes only... you won't have those on your tune menu... the predators work on several different vehicles, and depending on the vehicle it's hooked up to, you will have different tune choices...
if you hook up a 7194 to a vette, you will have those 3 tunes the seller mentioned...
if you hook it up to a truck, you will have the 3 tunes I mentioned...
yeah, diablo tune and diablo performance tune are the same thing man...
you don't HAVE to adjust anything, you can just install the diablo tune and go... but you will get some better performance if you do the data logs and adjust your fueling correctly...
dude, the tunes change a LOT of things... not able to list 'em all here, that's for sure
speed limiter is removed, TM is removed from the engine side, timing is adjusted, WOT PE fueling is adjusted, as well as a BUNCH of other stuff...
huh??? what do you mean by "petrol mixing" ???? editing for what??
08Sierra5.3L
English is not my first Language SO
for get about this ( huh??? what do you mean by "petrol mixing" ???? editing for what??)
your explanation is excellent and you are +10000000
thanks a lot
I will pm you when i buy mine
thanks a lot
My Car:
Sierra
2008
SLE
Stealth Gray
Sierra
2008
SLE
Stealth Gray
hahaha...
did you mean, like if you use different octane gas??? so instead of using 91 octane, if you used 89 octane??? yes, you can adjust WOT timing/spark advance for different octane fuels....
sounds good man, np... you know where to find me...
08Sierra5.3L
THIS WHAT I MEAN
IS IT EDITABLE
IN SAUDI ARABIA WE HAVE ONLY 2 KINDS OF PETROL
91 and 95 octane
for your information and advice if possible
91 octane costs me to fill up my tank some thing about 12$ green colore 100 Litter
95 octane costs me to fill up my tank some thing about 17$ red colore 100 Litter
IS IT EDITABLE
91 and 95 octane
My Car:
Sierra
2008
SLE
Stealth Gray
Sierra
2008
SLE
Stealth Gray
yes, you can edit the timing/spark advance... but only for wide open throttle....
08Sierra5.3L
one of my firends advised me aboiut the throttle BUT i dont beleive it will add HP
My Car:
Sierra
2008
SLE
Stealth Gray
Sierra
2008
SLE
Stealth Gray
also, since your gas ratings are different over there... your 95 octane is actually equivalent to our 91 octane, which the tunes are made for... so you should use your 95 octane gas over there...
your 91 octane is really only like our 87 or 89 octane...
08Sierra5.3L
aha
is your 87 octane with green colore??
about the throttle what is the best trade to sell the best one
My Car:
Sierra
2008
SLE
Stealth Gray
Sierra
2008
SLE
Stealth Gray
no, there is no color to our gas here.... it's clear, actually a slight little yellowish tint to it...
not sure what it is you're trying to say about a throttle.. . when I say Wide Open Throttle (WOT), that's a term for when you put the pedal to the floor... when you floor it, put the pedal to the metal... that's going wide open throttle...
08Sierra5.3L
aha now it come clear
I will download the diablo performance tune
if it seems bad I will change the petrol type to our 95 octan
My Car:
Sierra
2008
SLE
Stealth Gray
Sierra
2008
SLE
Stealth Gray
