06 mustang V-6..cooling fan on?
U7140 v.9r03 06 mustang V-6 airaid tune.just wondering why my cooling fan is coming on before the engine is hot enough for it to come on. After a 2 min drive not above 30 mph,pulled back in garage with car running fan came on slow speed then about 20 sec,high speed came on,when I finally found the colant temp in the programer (about 5 min) it said 194 deg. and fan never shut off.Is this normal for the fan to come on this soon? How do I get into change my global spark till I get good gas in it? thank you.
RE: 06 mustang V-6..cooling fan on?
You can modify the fan temp on/off by going into the custom tune for the tune you are running. Select the tune you are running then select customize. Page through till you get to the fan section.
- Vas@Diablosport
You should be able to adjust your timing and fan settings by going into the modify parameters section on your Predator.
No, i don't work here.
