06 GTO SURGING
yeah, please post up your log files so we can take a look at 'em...
MR_NO_EXCUSE
data log
Post by MR_NO_EXCUSE »
Here is the file. Thanks
RE: data log
you said it happens when you romp on it - go WOT right???
then do a log where you go WOT then please.... this is a normal steady driving/cruising log...
do a new one and get a couple WOT blasts in there....
did the surging happen to you when you were doing this log??
RE: data log
looks like maybe something with your throttle???
I notice that when looking at the accelerator position % in some spots where it'is steady -- the COMMANDED throttle position % fluctuates, from 12's up to 27/28's, in some spots..... from 12's up to 23/25% in others, etc etc...
interesting...
any thoughts mike??
MR_NO_EXCUSE
Re: RE: data log
06MonteSS wrote:you said it happens when you romp on it - go WOT right???
When I first noticed it was after I did a WOT blast, but now it happens while I am at cruising speeds. Yes it happen doing this log.
If I accel easy from a light it doesn't do it, but once I get to a cruising speed it starts too.
RE: Re: RE: data log
do you still have the tune installed in your car??
post up a copy of it...
here's info on how to copy the current diablo tune outta your car: http://diablosport.com/index.php?name=P ... pic&t=6547
MR_NO_EXCUSE
Yes, I still have the tune install. I will post it when I take my lunch break.
cool... also, post up a copy of your original backup tune as well....
exporting that from the predator is done the same way - but when you get to the export menu, select original backup instead of extra tune....
MR_NO_EXCUSE
current tune
This is the one that I have install right now.
MR_NO_EXCUSE
orginal backup
orginal backup
RE: orginal backup
cool.. will check 'em out right now and letcha know if I see anything funky...
gimme a few minutes...
MR_NO_EXCUSE
RE: orginal backup
ok, thanks
RE: orginal backup
what diablo tune is the one you have installed... the diablo tune for 93 octane, or the 91 octane tune????
MR_NO_EXCUSE
RE: orginal backup
91 octane
RE: orginal backup
k... well here's something interesting for ya....
I just compared YOUR "original backup" stock tune to 8 other stock original backup tunes for 06 gto's I have from other people... and, while their stock original tunes all match each other, YOURS does not match any of them....
and the upload.lan file you exported that's supposed to be the diablo tune does not match your original backup, so it appears that you did export them correctly...
sooooo, the "original backup" tune in your car is not a stock GM 06 GTO tune....
there was already a tune in that car...
