07 Ram Rev Limiter Problem
ElectricBlueHemi
Could I please get someone to fix my rev limiter problem? The rev limiter won't go above 6200 rpm even with the CMR tune set to 7000. Once the tune is set to 6200 or above, the truck just revs to 6200 and that's it. I can send you whatever you need to figure this out. I'm tired of limiting my motor with a 6200 rev limit.
Anyone else have this problem with a Ram?
ElectricBlueHemi
RE: 07 Ram Rev Limiter Problem
I know you guys are busy, but I would like to get this issue resolved so I can go to the track again soon. This is the only issue i'm having; everything else is working great.
Post the last tune written here please.
ElectricBlueHemi
Here is a base tune for my truck that just has an idle fuel adjustment and other minor adjustments to allow my truck to idle and this tune also has the rev limiter set to 6500. I have no "modify parameter" adjustments made in the handheld; all handheld adjustments were reset once I got a CMR tune to prevent the handheld from overwriting the tune.
Thanks for helping me fix this problem.
- 05094492AK_tune.drg
- (70.08 KiB) Downloaded 190 times
ElectricBlueHemi
Johan will be back on Monday...
ElectricBlueHemi
I think this one might do it.
Rev limit in D is set to 7100, shifts are set to 7000.
- 05094492ak_tune_7k.zip
- (70.21 KiB) Downloaded 181 times
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Diablosport INC
ElectricBlueHemi
ElectricBlueHemi
Johan, have you figured anything else out. What is the stock rev limiter? I thought it was 5700 or 5800 and if so, the +600 rpm adjustment in the handheld would make the rev limiter 6300-6400 and the rev limiter is only at 6200. I am 100% sure I have reset all parameters in the handheld to keep the CMR tune from being overwritten, so I don't know what else to tell you that would help you figure this out. Did you try to rev higher than 6200 on any 07's when you were testing them?
ElectricBlueHemi
