Jeep 5.7L Hemi
JeepWil
RE: Re: RE: Re: RE: Re: RE: Re: RE: Jeep 5.7L Hemi
Post by JeepWil »
is this ca-id in the update? or am i out of the luck... is there any solution to overide this block on the tuner?
johan
Post by johan »
Hmm, the server guy is out today i will have to check it out with him tomorrow.
It is a calibration update server issue on our end, the calid you have just needs to be updated.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
JeepWil
Post by JeepWil »
well i tried update initially and it didnt update. i found on another forum that there is a local.drg file that need to be use incase of firewall and that did a update but now i think its for the wrong car since at the end of it, it said it something about the ca-id that i have and its not compatible and superseed the tuner. without the local.drg, i am having trouble connect to the serer. it jsut said server reported and unkown errror.so i dont know if its my end of error or the server error you mention. so i am a bit lost. is calid update different from the .crom file?.lol..
This was a bit long.
Sorry
Have you tried doing it again, it should work now.
JeepWil
Post by JeepWil »
i tried. i keep getting unknown error from server. I turned off all firewall and went direct.. Is there a local.drg file for this that tells it to update?
Yes, post up the calid that is in your car now please.
JeepWil
Post by JeepWil »
caid-56044555AL
what revision is the predator on, I am assuming the latest, 9r17?
JeepWil
Post by JeepWil »
its one of the one that johan send to me. Its the beta version for the grand cherokee. i think yesterday he said my caid is in the update. i just need to update it. but i was unable with the normal process since i keep receiving server error... this is the version u7137-9t04a_export.crom
JeepWil
Post by JeepWil »
but i know it downloads cause when i download last time with a wrong local.drg.. the file downloads.. just not the automatic update
K, I am working on getting you the local file.
JeepWil
Post by JeepWil »
thank you thank you.. i been waiting to use this thing for a week.. looking foward to burning some rubber
email sent...
JeepWil
Post by JeepWil »
thanks for sending the file mikel. I tried the install today but kept getting a error. It goes through all the pcm ,and tcm. But at the last step when it ask to turn on and off three time, it just said calibration update fail. when i go into more, it said key cycle.
JeepWil
Post by JeepWil »
After that i tried to update the calibration and crom file. so it did its thing. For calibration update, the first time it said the memory is full. the second time it worked. Then i tried crom file. The thing did the preparation screen. then when it boot the predator, it hang and the predator did too. So now i got the corrupted file screen. Then i did the manual update without autoconnect. Voila got program. But once i connected to the car, it turns on but wont read the info. The predator just keep telling me to turn key on. What can i do?
