Anyone running the regular tunes AND the puck?
Dodgezilla
Post by Dodgezilla »
I installed the regular Extreme RKL tune today and the truck runs totally awesome. I turned the Puck off because I figured the DL is giving me some pressure already. Has anybody tried running this program plus the puck too? Or will it just be too much pressure?
I'm going to dyno next weekend and, of course, I want to make the most power possible...... 8)
04 Ram 2500 RARE Timberline Green 4x4 305/555 CTD/Stock48RE,DS Predator,VA C3.2,HE351 turbo, 2nd gen intake, BHAF,Custom 4" exhaust, More stuff....
dunejunkie
RE: Anyone running the regular tunes AND the puck?
Post by dunejunkie »
ran it with puck on high and low not much cahange in fuel pressure
06 mega cab predator/puck stack,afe stage 2,cfm+ plentum,zilla boost fooler,maghytec deep trans pan, a-pillar gauges and 5 inch exhaust
Dodgezilla
But how did it run? Any change in the way it feels? Stronger? Weaker?
trik396
Post by trik396 »
I ran non stackers with my XZT. Made 573hp. Probably at the limit as far as pressure is concerned. Wouldn't run it that way everyday. If your fuel system isn't up to snuff, or you start draining the rail, you'll make crazy smoke, less power, and way too much heat. Watch those temps...
2005 DodgeRam 2500 4x4 CTD
A little of this, some of that... 573rwhp/1200+trq
Dodgezilla
I'm still running the stock LP so I may wait until I get a better LP before I try it. Maybe....
dunejunkie
I noticed a little more power but it smokes a considerate amount more. It pulls really hard at about 3000 rpms
Dodgezilla
Mine smokes a lot anytime I am pushing on the go pedal. Anymore and I will start getting tickets!! I had to extend my 6" tip out about 3" further to try to keep the soot off the rear fender.....
NEVERENOUGH
Post by NEVERENOUGH »
Dodgezilla, you will definately need to repace the LP to run it with the regular non stack or rkl tunes. I ran my rail dry with a modded fass and twin pushers (dirty filters lol). I was very :oops: when that happened. Once i replaced filters i noticed a big difference.
Dodgezilla
I remember running the rail dry on my 03 w/ a TST?MP8 stack. I can tell you that I have not felt that in this truck yet. We'll see how she does on the dyno this wekend. If it doesn't hit 450+hp then I know it's time to upgrade the LP. I've got the $$$, I'm just too cheap to spend it....
NEVERENOUGH
LOL, goodluck.
