need a diablosport tech to contact me!
I need to get in touch with one of you Diablosport techs. I am having my car (2005 SRT4) tuned by a cmr tuner and there are some error codes that will not go away! He has tried countless times through different tunes but they still come back when they shouldn't (especially overboost code).The info from my car was sent to you over five weeks ago and still no remedy.
Please pm me with an email address so I can give full details including tuners email so you can get in contact with him directly. Thank you.
RE: need a diablosport tech to contact me!
The tuner is getting error codes or your car is throwing codes? Overboost codes are common when boosting over stock psi. A stage 1 pcm will do away with the overboost codes.
The codes should not be occurring due to cmr custom tune. Now please techs only. If you work for Diablosport then great, i need to talk to you. If not, please dont give your opinions.Still need a tech to chime in. If the last poster is a tech, then I am sorry but there is nothing identifying you as one. Please let me know if you are and we can continue this conversation further.
definitely!
mods:
3" cai
3" o2 housing
3" catless exhaust
Forward Motion WGA (pcm controlled, boosting 21, starts falling around 5000 rpm's to about 17 at 5600 rpm)
stage two injectors
Forward Motion
E1 turbo
Boomba BOV
NGK Plugs
180 degree t stat
Walbro fuel pump
W/I injection (not being used in the tune yet)
stock pcm
Tune is attached.
I get p0234 (overboost) after two or three pulls.
mods:
3" cai
3" o2 housing
3" catless exhaust
stage two injectors
Forward Motion
E1 turbo
Boomba BOV
NGK Plugs
180 degree t stat
Walbro fuel pump
stock pcm
Tune is attached.
- erik_tds_8.drg
- (38.35 KiB) Downloaded 103 times
Give this one a shot and let me know.
- erik_tds_9.zip
- (38.47 KiB) Downloaded 117 times
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Diablosport INC
well tried the tune and didnt go so well. Second gear boosted to almost thirty psi resulting in a tb vac line blowing off. After the line went, bov no workie all the way home.
Not sure what was changed, but with that tune before the car boosted to around 20 psi. Let me know what you think Johan
- johmoore133
can u look at a past tune for john moore not working havent
04 srt4 stage2 injectors full 3in exhaust cai ecu stage 1
Sarcasm not really necessary....buzzkill wrote:wow! thanks for the continuing support.still nothing from you but my tuner and I are working it out. Brian will be missed.
Your "tuner" should be able to figure it out i would think.
Attached a new file for you...
- erik_tds_10.zip
- (38.48 KiB) Downloaded 128 times
Diablosport INC
Diablosport INC
