E350 POWERSTROKE VAN STACKING YOUR POWER PUCK
I HAVE AN 07 POWERSTROKE VAN E350 WITH A BULLYDOG TRIPLEDOG AND OULOOK MONITOR. 4 INCH DOWN PIPE EXHAUST AND INTAKE. RUNS GOOD BUT WANT ALITTLE MORE. CAN I STACK YOUR POWER PUCK WITH MY TRIPLE DOG DOWNLOADED? AND IF THATS THE CASE I WILL NO LONGER BE ABLE TO USE THE OUTLOOK MONITOR BECAUSE THE OBD2 PORT WILL BE USED WITH THE PUCK CORRECT? ON TOP OF MY POWER NOW WHAT TYPE OF NUMBERS WILL I SEE INCREASED?
RE: E350 POWERSTROKE VAN STACKING YOUR POWER PUCK
The Puck is inline, so it does not plug into the OBDII port.
Should be fine.
Should be fine.
SO THEM WHERE DOES IT PLUG INTO IF IT DOES NOT PLUG INTO THE OBD2 PORT? AND IF IT IS NOT IN THE CAB HOW DO YOU ADJUST ON THE FLY.. ALSO ANY POWER INCREASE NUMBERS?
Plugs into the ICP harness, and the power knob runs through the firewall for adding up to 100HP on the fly.
