Shell gas with nitrogen.
ZMagnum
Post by ZMagnum »
I know Shell gas is not on your recommended list but what do you guys think of the new Shell V-Power gas formula with added nitrogen? Will this help a Predator tuned car? Do you think it will help reduce knock? The nitrogen is supposed to keep the engine's fuel system and valves cleaner. Maybe it's just hype?
johan
RE: Shell gas with nitrogen.
Post by johan »
Not really sure to be honest with you.
However i have noticed that Shell did something with their fuel within the past few months as it has gotten much better.
We have a station right around the corner and many customers fill up there before they come here and lately that has not been an issue so they did something right this time.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
ZMagnum
Post by ZMagnum »
Great. That's good to know. I will give it a try.
DGatzby1
Post by DGatzby1 »
Magnum, give some a try and datalog it. Let us know how it compares to other fuels.
2006 300C-SRT
185 T-Stat/Catch Can
DiabloToona CMR Gas tune
Extra "Flex" E-85 tune
SRT8_T
Post by SRT8_T »
its the same thing as techron in chevron gas.. we had a bio fuel engineer in class spaeking to us and i asked him the same thing.
Someguys300c
Post by Someguys300c »
personally im very skeptical about this. there is obviously a lot more to it, than nitrogen enrichment. i run the plants, that make 1/3 or so, of the oil you guys get in the states. Gasoline is made from cuts of this oil. and one of the main things we do to treat it, is remove the nitrogen. we have to stay below 22ppm nitrogen in our product, or it can cause big problems for the refineries downstream. so this sounds like crappier gasoline to me, if it contains more nitrogen. nitrogen is an inert gas. so by putting more nitrogen in your cylinder, you take away volume, that could be held by something that burns. which is what creates power.
ZMagnum
Post by ZMagnum »
I'm going to give it a try on my next tank. Predator in hand.
Re: RE: Shell gas with nitrogen.
Someguys300c wrote:personally im very skeptical about this. there is obviously a lot more to it, than nitrogen enrichment. i run the plants, that make 1/3 or so, of the oil you guys get in the states. Gasoline is made from cuts of this oil. and one of the main things we do to treat it, is remove the nitrogen. we have to stay below 22ppm nitrogen in our product, or it can cause big problems for the refineries downstream. so this sounds like crappier gasoline to me, if it contains more nitrogen. nitrogen is an inert gas. so by putting more nitrogen in your cylinder, you take away volume, that could be held by something that burns. which is what creates power.
What can you tell us about BPs Invigorate? The Hemi really seems to like the stuff what ever it might be. Or it may just like it because its in the gas with no Ethanol. Either way I'm curious.
PS: The Hemi loves a bit of NitroMethane in the tank. Changes the sound a lot and runs real strong. :twisted:
Someguys300c
sorry. i dont even know what gas station BP is?? pretty sure we dont have them in Canada. and i dont keep up on that stuff much anyways. i always use shell fuel, since its known to be the best. but the whole nitrogenated fuel, sounds like snake oil to me. im sure there is something to it, but they just arent telling you the science behind it.
DGatzby1
RE: Re: RE: Shell gas with nitrogen.
Post by DGatzby1 »
Mike, I can tell you that BP is the only gas around here that I can log without getting ST Knock on even the 91OCT tune. I have purchased other brands of 92 octane gas that show ST Knock with the 91OCT tune! FYI they are now selling a 93 octane product around here (FINALLY) and on our Jeep it runs clean on the 93 octane tune. I have not been able to log it with the SRT yet, but will next week probably.
2006 300C-SRT
slack-axe
Post by slack-axe »
Mike_Levy wrote: What can you tell us about BPs Invigorate? The Hemi really seems to like the stuff what ever it might be. Or it may just like it because its in the gas with no Ethanol. Either way I'm curious.
BP with Invigorate has given me the lowest ST KR readings of any brand I have tried so far with my 5.7. I went from the "non-nitrogen" Shell 93 (ST KR of 6), to Exxon 93 (ST KR of 2.5), to BP 93 (ST KR of 1.5).
I hope the BT Catch Can I am purchasing helps a little with that last bit of ST KR :twisted:
07 300C: Predator / 170 TStat / Flowmaster Super 40's / AFE Stage II / BT Catch Can
13 Jeep Wrangler JK: inTune DCX / AFE Pro-Dry drop-in
cleary524
Post by cleary524 »
catch can should help w/ knock reduction. Did for me.
05 Mag RT AWD
AFE Stg II CAI
Magnaflow C/B
JBA High Flow Cats
Edelbrock Shortys
SLP 25% Underdrive Pulley
Ported Throttle Body
Jet 180 T-stat
Tune by Johan
BT Catch-Can
fordomatic69
Post by fordomatic69 »
The Shell gas in Ontario (Canada) is really quite good stuff. There is a sticker on the pump that lists the ethanol content of the 3 gasolines:
87 = 10% Ethanol
89 = 5% Ethanol
91 = 0% Ethanol (V-Power). I like it and use it when I am running the 91 CAI tune. The only time I can run the 93CAI tune is when I am running Sunoco 94. There is Ethanol in Sunoco 94 but that extra 1 point in the octane rating offsets the ethanol so it does not show up as Knock Retard when I am at WOT.
Fordomatic Says:
"I've heard of Vaporware... but I've never actually seen it" :lol:
http://www.twincamlubricants.com - For all your synthetic lubricant needs. Order Online and save over retail.
fordomatic69
Isn't Nitrogen, in it's liquid form very COLD? If you take gaseous nitrogen and compress it (like say during a compression stroke) would it not compress into a semi liquid state, which would cool the air within the combustion chamber, making it more dense? We all know that denser volume of air in the combustion process improves performance (the whole idea behind NOS). Just a theory of mine (I'm no chemist or expert for that matter). :lol:
Fordomatic Says:
DiabloFan
Post by DiabloFan »
Whe you compress a gas, it gets hotter, not colder.
