pucks
dunejunkie
pucks
what is the difference between the normal puck and the extreme besides the boost fooling? are there any horsepower diff? i like the nob instead of the micro switch seems much stronger. thanks for any input
06 mega cab predator/puck stack,afe stage 2,cfm+ plentum,zilla boost fooler,maghytec deep trans pan, a-pillar gauges and 5 inch exhaust
RE: pucks
The extreme is rated from 0-100 HP on the fly, while the standard puck has 3 settings, off, +60 HP and +90 HP.
dunejunkie
RE: pucks
Does the extreme run more or less fuel pressure than the standard puck? Seems that every time i pull with the puck on,both in the 60 and 90 settings I throw a fuel rail pressure codes. Maybe if the extreme runs less pressure I could use it to pull with..
