performance tune load = FAIL
hemi-dad
Post by hemi-dad »
ive tried twice to load the performance tune into my 05 hemi ram and both times it goes through the PCM and TCM writing and when i think it should be done is says the writing tune or whatever it is, has failed and i have to reload my stock tune before i can even crank the truck..... HELP
hemi-dad
RE: performance tune load = FAIL
Post by hemi-dad »
it keeps saying something like " writing failed, please make sure ign key in ON but the engine is NOT running " but the ign key is ON and the engine is NOT running. so.... ???
johan
Post by johan »
What revision are you on?
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Remote start or trailer brake installed?
Glenno
Post by Glenno »
It seems that a few of us 05s have this problem.
http://www.diablosport.com/index.php?na ... 5264#85264
I got mine to load eventually. The real kicker is that every time I want to change a parameter, I have to go through the flash process several times to get it to take. To make it worse, when the upload fails, it goes back to stock instead of the last written tune!
Mikel - If you're tracking these, I do have the Mopar Remote starter.
Glenn
hemi-dad
Post by hemi-dad »
i think my problems were amp hooked to battery and e-brake was on. i took amp power wire off and didnt use the e-brake this morning and it loaded the program
Black05Hemi
Post by Black05Hemi »
Uh huh, it's done it to me too on my '05 Ram...Just gotta keep trying, and make sure your battery voltage is 12.8 or over
This tuner is very picky, unlike the Superchips I used for years, with no issues...
whitehemi
Post by whitehemi »
David is right the DSP is giving some of us some fits when it comes to loading certain parameters. Johan I sent you a PM....
Quick
Re: RE: performance tune load = FAIL
Post by Quick »
Black05Hemi wrote:This tuner is very picky, unlike the Superchips I used for years, with no issues...
Probably true. On the hemis the Superchips doesn't do anything...
2006 Magnum SRT8
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
