u7137 2005 hemi ram 6.4L 392 8.8 comp boost cam port and polished fully studded headman longtubes into headman 3inch y-pipe thru 2 bullets back 2 back dumped.
I would like to know what i should upgrade from stock in the fuel area of things. the motor will be making around 700 flywheel horse power.
also i was wondering if diablo sport in delray beach tunes vehicles with predators or where they would advise me to take it.and
Serious questions on upgrades need
RE: Serious questions on upgrades need
How does that even run? You definetly need injectors, probably logs, and a boost-a-pump, if not a whole new pump.
What will be making boost?
Id look into a set of siemens/deka 60# injectors at the minimum.
- 6.4hemiram
it has a novi 1200 on it. it runs like s*** thats why i need to know what to do and is there any way to bypass the intake regulator and do a retur system some how
Yes, you can do a return fuel system, several others have done it.
Should not be too tough to tune, shoot Johan an email when its done, maybe he can help you out.
