no PC connection option on U7193
Orngasm
Post by Orngasm »
I just tried to download my factory tune onto my computer and followed the 96-02/ 03-06 pc interface instructions and I didn't have the PC connection option under the options menu. Confused? I downloaded the Vista program being that i have Vista OS. Help? What did I do wrong? Shouldn't I still have the PC connection option in my programmer?
#238306
v.9r07
2005 Avalanche 2500 w/ 8.1
Solid
RE: no PC connection option on U7193
Post by Solid »
Hello Orngasm,
If i'm correct you have to download the program from the download section http://www.diablosport.com/index.php?mo ... ay&pid=134 then download DS Downloader (production version) and install that on your computer. then just follow the steps as the screen shows. If you're predator isnt reconized by the software make sure your using the right com ports 1,2,3,4 if i state correct. And the Baute rate has to be similair as in the software and the predator.
You can try this. I had a problem with my U1794 because the interface instructions didnt aply to my predator.
Greetings Solid
Orngasm
Post by Orngasm »
Thanks Solid, I was wondering what that Baute rate was all about. I will try this again. We'll see what happens.
Robert
you want the baud rate to be set at 115,200 for the cable... check the properties of it in the Windows Device Manager...
and yes, you want the com port to be set to 1, 2, 3, or 4...
New tools will auto connect, no need to set COM port or baud rate...
Orngasm
Post by Orngasm »
Okay Monte I'm one step further than I was yesterday thanks to Solid. However, it wants me to hook it to Com3 and those are the usb's on the back of the puter. The cable is not long enough for those. My front usbs are COM4,5,6 & 7. In the dropdown box it's only giving me COM3 option, no others. Anyway to change this? The baud rate was changed so I've done something right! lol
Robert
Re: RE: no PC connection option on U7193
mikel wrote:New tools will auto connect, no need to set COM port or baud rate...
heh, have gone through this enough times with a lot of people to know that this is not always the case... ;)
they've had connection issues, and once the com ports and baud rates were changed, bingo! they were working pefectly...
Orngasm wrote:Okay Monte I'm one step further than I was yesterday thanks to Solid. However, it wants me to hook it to Com3 and those are the usb's on the back of the puter. The cable is not long enough for those. My front usbs are COM4,5,6 & 7. In the dropdown box it's only giving me COM3 option, no others. Anyway to change this? The baud rate was changed so I've done something right! lol
Robert
go into the Windows Device Manager and go to the USB port properties...
change the current usb port on the back that is com 3, to some other number...
then, go to the properties of one of your front usb ports, and assign it to be com 3...
reboot, then see if you're able to connect...
Solid
RE: Re: RE: no PC connection option on U7193
Post by Solid »
Hey,
Sorry that i havent helped you any more. But i didn''t had time to to post :$ So how did it go? My new predator didn't connect automatich aswell it took me about 1,5 hour before firguring everything out. If you have any quistions feel free to ask but i think you have the best help already from 06MonteSS.
Good luck with everything!
Orngasm
Post by Orngasm »
Thanks guys, I will do the re-number thing with the coms. I'll let you know. Yeah, the auto cionnect thing wasn't working to good. Once I shut it off, I only had one option for a com port. Thanks again.
Orngasm
Post by Orngasm »
Well, no good news. I called Diablo today and they told me that I needed to install the driver that came with the cable... I did that. Nothing. I looked into it further and noticed there were no instructions for Windows Vista OS. Went to the help menu in the Diablo Downloader and found a driver there for Vista. Downloaded that one and... still nothing. Any other suggestions? I wasn't able to change my usb port numbers... that's a whole new adventure I went through! Help! :crashing:
Solid
Post by Solid »
euhm well lets make sure about some things first just to rule things out.
I'm sorry if somehting is called different in your vista i'm using a dutch version and doing the translation out of my head.
You did install the driver from the cable correctly?
you got the new hardware wizard?
So your for sure the computer reconaised the cable?
Did you download this driver http://www.diablosport.com/beta/PL-2303 ... taller.exe ? If not delete the drivers you used. and try this one.
If you did download this one try ro delete everything you installed such as drivers for the cable. And then try instaling them without the cable in the pc. Restart the pc and then when windows is done loading everything insert eh cable in the usb port. Then i hope it will instal automaticly. You can't change any port before the cable is reconized. I don't have the com ports listed here in the device manager aswell because i'm on the work computer. When i get home i will try to hook my cable up to my vista pc. When i connected the cable i was at my dealer who uses XP. So all i'm doing is giving some thought about what i would do.
But if youre computer has reconaized the cable there should be a line in the device manager with something like com and an sing of e cable like thingy infornt of it. then you can change the com port by going trough the properties. As MonteSS Said before.
Hope this helps if not i will think about it and post back to you. But there is a 6 hour time differance with you guys. So sorry if it takes long.
Greetings Solid
Orngasm
Post by Orngasm »
Thanks Solid. At this point I am open to everything. I will try all that you suggested. I think I'll just delete everything and start from scratch!!
Robert
Orngasm
Post by Orngasm »
Gentlemen, I tried everything Solid suggested. I actually see the computer trying to find the driver for the tool. Plug cable in to usb and I get "searching preconfiqured driver folders" after a few seconds I get this "Device driver software was not successfully installed" Please consult your device manufacturer for assistance getting this device installed.
Prolific USB-to-Serial Comm Port (COM12) Failed
I shut off my firewall when I downloaded the program from the Diablo website thinking that was the problem. No such luck. I've tried all the USB ports and keep getting the same message but with the different COM #'s! What else can I try? I think I've tried everything besides sending the cable back to Summit... that would not make me happy. How can a cable go bad sitting around in a box? lol
I'm open to any suggestions. Maybe I should call Diablo when i'm sitting in front of my puter and they can walk me thriough it. But I think I've tried it all.... with my limited computer knowledge!
Thanks for all and any help.
Robert
Solid
Post by Solid »
Hey,
Well there is 1 upsie to your story we now know for sure that the driver isn't installed correctly causing all the trouble. So my best guess is that you have to download the software driver from Prolific wich is the cable manufacture. just to make things clear you need in fact 2 programs. 1 is the software from diablo DS downloader. And the other is de driver for the cable. The driver is need to tell the computer that it is a usb tot serial kind device. the other software is for reconaizing the predator. Try downloading this driver http://www.prolific.com.tw/support/file ... _10311.zip and install it without the cable connected.
I dont think you have a problem with the DS downloader software. It opens right?
So try this and then when the driver is installed you should see it reconais the cable. then you can change the port number. And then DS downloader should connect.
if not get back and ill think of something different.
Good Luck!
