logging with myU7195 and tuning ?
gasjob2500hd
Post by gasjob2500hd »
one i cant figure out how to do a data log i go to diagnotstics, real time data
and it brings me straight to the real time data i never have any chance to select gas general short as stated in the directions for DSLogReduxlogging
ive down loaded the program i have the cable and all
what am i missing when it comes to making the actuall log
also ive taken off those 2 torque managment settings im on the 87 oct tune due to gas prices (i actually think it has more power with that tune as to the performance tune i dont know why??)
and i modified the shift points and shift pressure when in tow haul
what else should i do idk how to mess with the fuel curve or timing what should i do?
i have an intake and exhaust if that matters
o and its a 2003 chevy 2500hd 6.0 lq4 4x4
RE: logging with myU7195 and tuning ?
that model predator most likely does not have the option to select parameters... it just logs them all...
also, what revision is your predator on?? is it a new 9rxx revision?? the number is at the top of the screen when the predator has booted up and is at the main menu...
I found an old post of yours that says you bought the predator in december 2007... if that's the case, it is an old 2.xx model/ revision and you can't save data logs to your PC - so, you can't use dslogredux or the dataviewer either...
you can only view the info live on the predator screen while you drive.
gasjob2500hd
ok yea im sure your right well that sucks
what is this 9rxx
can i get it some how?
do you have any suggestions for tuning?
you would have to pay $$$ and send it in to diablosport to get it upgraded to the new version..
here's info about the upgrade program... http://diablosport.com/index.php?name=P ... ic&t=10946
Return to “Predator GM Gas”
