af ratio?
CANUCKPREDATOR
RE: af ratio?
a/f ratio is fixed under cruising anyway. only time it will be different is WOT. not sure if your model can read it. some ECMs didn't report a/f ratio. you'll have to wait for a smarter person than I to answer that one.
RE: af ratio?
yeah.. what vehicle do you have? what year is it??
RE: af ratio?
Need a wideband O2 sensor to see A/F.
RE: af ratio?
so i dont need af ratio for the program work
RE: af ratio?
for what program to work, DSLogRedux?? no, it will detect that no AFR parameter is available and prompt you - asking you if you're logging with an older style tool (7198, 7192, 7193, etc etc)... select YES and it will still go through and analyze your log for your average LTFT's and recommend the injector slope adjustment for you to make.
but it will not do any WOT info/data, since there's no AFR available.
