Documentation Please
joshag
Post by joshag »
Predator U7130
9r05
O5 Dodge 2500 5.9L Cummins
Is there any documentation describing all the features and functions of the Predator unit. There appears to be much more to the unit than applying custom tunes but nothing written to explain what they are or how to use them.
Any resources with explainations would be appreciated.
Thank You,
blackmagic1
RE: Documentation Please
Post by blackmagic1 »
check it!
http://www.diablosport.com/index.php?mo ... lay&pid=73
and download
Predator Manual 03-07-07 manual_U7130_U7131 (pdf)
hope that i m help you!
joshag
Post by joshag »
I own the U7130 so the only thing new here is the U7131 info.
The explanation for "real time data" is "View real time data, this group is set up in groups of parameters to view". That's it. No explanation of what the parameters are or how to set them up. You can guess at what some of the abrevieations mean but still nothing to confirm. Can I leave the unit plugged in at all times? If I shut the vehicle off do I need to disconnect the unit or will it shut off by itself? It seems that there can be several groups set up but without explanation. Can I view tranny oil temp without a sensor? No but that is not explained.
I realize that it has only been about 3 weeks since the last update but still no revision history. If I had the 7131 I could change settings on the fly. Can I do this with the U7131? No. The only way I know this is because someone with a 7130 had to ask in the 7131 update post.
Who knew that you can actually change the settings while driving with the 7130? It will not change on the fly but it can be done. This tidbit was thrown out there by the mods (still have to wait 10 minutes and I would never trust it.
If there was a new software update. What did the U7130 users get?
You don't know because there is NO DOCUMENTATION!
joshag
Post by joshag »
Remember:
There are only 2 things that are infinite, the universe and lazy coders. I'm not sure about the former.
blackmagic1
yes you can leave the unit at all time!Personnaly i tryed 30 min!
if you shut down the vehicle! you need unplug the unit all time(i don't know if the unit shut down after few time)
yes i could view tranny oil time! (the PCI control the up shift and down shift which the oil temperature change,i view on the manuel shop), the unit 7130 ,you don't change the setting on the fly!same thing for u 7131!(STop me if i wrong),
only the PUCK you can!
and the unit 7130 work only for cummins 03-04-04 and the unit U7131 work only for cummins 06-07
. i hope you understand my english!
