Odd Surging
jongohr
Odd Surging
Post by jongohr »
Car: 2009 Dodge Challenger R/T Auto, AEM Brute Force CAI, Pypes Catback with Violator mufflers, Modern Muscle 85mm ported throttle body, BT Catch Can.
Filled the car today with a full tank of Amoco Ultimate 93 octane and then installed the 91 octane cai tune. This was my first time installing a tune on anything and it went very smoothly.
In manual mode the car is a beast, got rubber on the 1-2 and 2-3 shift. Was really impressed.
In automatic mode and cruising at any speed the car will surge oddly and seems to not know what gear it wants to be in. Should I reset adaptives? Disable MDS (Can we do that)? Data log and send to a good tuner?
Any advice will be appreciated.
RE: Odd Surging
Its probably the TB. Did you have the blade calibrated with a StarScan?
Quick
RE: Odd Surging
Post by Quick »
Try disabling the MDS before looking further. When cruising it kicks in and out. The tunes reduce torque management and then you can feel the MDS switch.
Go to the perf tunes section, select the tune, then go into modify parameters... then you just have to find the MDS parameter and turn it off (I have no idea which sub menu it's under). Menu out and install the tune.
2006 Magnum SRT8
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
jongohr
RE: Odd Surging
Post by jongohr »
I've had the throttle body on for over month prior to installing a tune. So my guess, from reading other similar threads, is that this is a MDS related issue. Will modify the tune when I get a chance and see what happens. Thanks.
Nickrt
RE: Odd Surging
Post by Nickrt »
Have read elsewhere that the Diablo team can modify your program so that the MDS still works but without the surge. May want to check in with them before you disable.
jongohr
Re: RE: Odd Surging
Post by jongohr »
Nickrt wrote:Have read elsewhere that the Diablo team can modify your program so that the MDS still works but without the surge. May want to check in with them before you disable.
Thanks for that info ... if that is indeed the case I'd love to get that tune. Anyone from DS have any input?
Thanks!
jongohr
RE: Re: RE: Odd Surging
Post by jongohr »
Not sure if anyone from DS has read or is following this thread?
Drove the car 40 miles today and have to say it's virtually undrivable in automatic mode. The surge cruising at 55 to 60 mph in automatic mode is terrible. I would even say it feels unsafe.
I've only been able to try the 91 octane CAI tune. The best gas in my immediate area is 93 octane Amoco Ultimate at a BP a good distance from home. Everyone else only has 91 or 92. I have serious doubts whether the BP 93 is good enough for the 93 octane tune.
So is MDS off the only solution or is there a better tune available for the automatic cars with the U7135 and 9r17?
brandy16
Post by brandy16 »
Turn the MDS off. and see if it stops surging. My car a 2006 300c did the same thing. I had to turn the MDS off. The tune will give you better fule milage so if you turn off the MDS you should be getting the same or close to the mielage you got without the tune and the MDS on. Give it a try and see.
fireman2118
Post by fireman2118 »
I had surging in my car (R/T) until I turned the MDS off.
'05 Magnum R/T - 400 rwhp - 385 rwtq
PPP stage 3 heads, Howards cams 219/227 .600/.575 112 +4 , Ported 6.1 intake manifold, 85mm TB, JBA headers & mids, Corsa Sport, Dominator 3000 stall TC, stage II valve body, Getrag 3.91 LSD, BCR coilovers, Eibach sways, BWoody links, Wilwood big brake kit
yeah, it's your MDS system.. disable it...
the same thing happens with GM's DOD/AFM...
so either disable it, or ask the diablo guys if they'll make you a custom tune to fix it.. it is doable via a custom tune, cuz I've done it for other GM users and our DOD/AFM system...
CaptainJ
Post by CaptainJ »
I have MDS off and it still surged for about 4 weeks after a new tune until the computer re learned what was going on. (I guess) At any rate my car always settled down after a few week after re-flashing.
2006 Dodge Charger R/T, CAI, 185 T-Stat, 85MM T-Body, NOESP, BT Oil Catch Can, exhaust.
PreadatorU7135
SN 225583
V.9r12
jongohr
Post by jongohr »
Thanks for all the info everyone!
I restored the stock tune this morning for the drive to work. Miss the snap of the tune but not the surge.
I'll modify the tune and turn off MDS as soon as I have time and see if I like it. Probably after the first oil change which is coming up pretty quick.
smssupercars
Post by smssupercars »
Let us know when you try it!
jongohr
Post by jongohr »
Modified the tune and disabled the MDS. That does appear to fix the surging problem.
rham48
Post by rham48 »
Mine is doing the same thing (surging) while cruising on the freeway. I'll try turning off MDS, thanks for the tip! Russ
