Predator U7191 not connecting to PC
bookemdano
Post by bookemdano »
hey Mike/Johan/06monteSS hows it going.
I posted on ls2gto forums regarding an issue with the predator not connecting with PC. so far i resolved the problem with the serial to usb connetion. i dont see the yellow "?" on device manager anymore. I did a fresh usb serial controller install and boot up... now back to my dillema. i downloaded the GM ls2 interfaceinstaller, once installed i re booted, so far so good. i powerd up the predator connected the Serial to USB, and open the interface installer. i follow the procedure, options, serial baud change,custom tune. export tune, original tune, the tuner goes into (processing 5%) and stays there. on the bottom of the GMinterfaceinstalerl i get a waiting for communication message. then 5 seconds later the predator reports (transfer failed).... i have tried com1,- com2, port setting 115200 on both com1,- com2,. forget about the serial to serial as soon as i connect the serial cable to the predator i get the dredded (transfer failed)screen of death... i am begining to think maybe this predator U7191 has a problem.. may need to talk to marrylandspeed regarding an exchange or refund.....JM.... ps 06/GTO-A4..
bookemdano
RE: Predator U7191 not connecting to PC
Hey mikel, hows it going..we spoke on the phone the other day regarding this issue.
But thanks to Perceverience!!!! I finally got the predator comunnicating with the PC.
I Uninstalled everything and anything that was associated with USB, diablosport.
And did a fresh boot. then i looked in the add remove program to confirm deletion.
Then to the device manager, looked for anything out of place, All good.
Then i installed everything back, and re booted for every application..... THANK`S for trying...WOOOOO!!!! HOOOO!!!!
Now i dont have to worry about sending anything back. The 93 tune is Awsome! sure would of hated to give it up..
Cool, glad you got it to work.
Lemme know if you have any other issues, I'm right in the neighborhood...
bookemdano
Stop by and say hello. 5102 sw 92 terr. on friday nights i usually go to towers..
maybe we will meet, and talk the talk!!!
Re: RE: Predator U7191 not connecting to PC
bookemdano wrote:Stop by and say hello. 5102 sw 92 terr. on friday nights i usually go to towers..
Cool man, I'll prolly be at Towers myself...I assume you park with the Goat herd up front?
bookemdano
RE: Re: RE: Predator U7191 not connecting to PC
Yes mike, i have a spice red goat. you cant miss it, it has a goat badge instead of the pontiac badge...lol....
at the rate were getting rain it might be a no show!
but it`s all good. my wife say`s i have become a data log "JUNKIE"....
cant help myself, i have been out on US 27, 8 times since sunday DATA LOGING the GOAT..."lol".....
you bunch of goat herders you!!! :lol:
glad you got it to work man!!
bookemdano
Hey MONTE hows it going, I took your tuning class "101" and was doing good.
My ltft were kind of high -6.250/-6.250 bank 1/ bank2/sensor 1-2.
i went possitive on the injector slope 5% and it got me into the 0.7838 both banks.thats the way it shows on the dataviewer.i went positive on the PE 5% but i started to get some knock retard. its been raining bad around here specialy when i make my runs. LATE at night. lol...so i have not been able to go out and make a run, and log.
we have a verry loooong strech of interstate with a speed limit of 65 mph.
and at 1:00 am there is nothing but "bugs" out. soon i will send you something.
Man i am having a blast with this new toy. i am a disabled american vet, gulf war, operation desert storm.
i got all the time in the world, thats why i could go out at all times of the night to play. "LMAO"....
if you had to go +5% on injector slope - which means you leaned it out... and you're still getting KR at WOT, then set both PE ranges to +8% for starters, and we'll go from there.
if you went +5% on slope, and left the PE settings alone, did you get any KR? or did you only get KR AFTER you set the PE ranges to +5%??
Return to “Predator GM Gas”
