I installed the canned tune wiith the 3.42 change. I want to be sure all adjustments are in the ballpark area. Does anyone have the settings you are using.
Shift points
MPH RPM etc
2.73 to 3.42 1999 Corvette automatic
i have a 02 Camaro A4 and just went from 3:23's to 3:73's. I need to do Tranny shift point also, it's going to take some logging of shift points on a laptop to see when shifts occured via TP,MPH and RPM. I did read somewhere that Vettes are commanded by a different set of parameters?
At least this post will get this post, TTT:)
Lower your MPH shift points by the same % as your gear change...
