DS Downloader Installers
Questions and comments specific to the DiabloSport Downloader application.
Locked
johnc
Post by johnc »
The latest release of DSDownloader is available through the following link(s):
http://www.diablosport.com/index.php?mo ... ay&pid=153
2.2.2.5
Use a case insensitive CalID string comparison when generating tune diff records
Return CalID from VID block in Upper case
remove filename extension (e.g. tunename.frg) when generating diff_names
2.2.2.4
Open file in shared read mode for Trinity CROM auto update.
(Allows multiple instances of DSDL "gang" auto-updates)
2.2.2.3
Fix CROM delete/cleanup on Trinity.
2.2.2.2
Update all Trinity CROM on unmarried device.
Change Tune import/upload prompts.
Indicate if Tool is married to another Application (Tinity)
Allow loading full-tune without asking for base file (u7146)
2.2.2.1
Not released on website
2.2.2.0
Remove "Disconnect" on bottom status bar after successful connection with Tool has been made.
Conditional installation of Trinity USB drivers
Increase memory allocation size for unencrypted/uncompressed bin payloads
Display last Internet Server error in Help->Tool Info dialog
2.2.1.9
Post dialogue prompt if locked CMR tune or erased custom tune detected in Multi-ECU tools.
New Trinity Browser capability for transferring dashboard files between Trinity and PC/Laptop
Include ability to manually run Trinity registration wizard.
Correct legacy tool CMR tune downloading
2.2.1.8 (not released. Internal only)
Propagate VIN from custom tune file instead of ORI when installing in Tool
2.2.1.7
use TEMP folder for calibration update file downloaded from Website
Save copy of last tune written to tool in "My Documents\DSDownloader\send_tune_to_tool.cry"
Changed "Send CROM File to Tool" TO: "Update Tool".
2.2.1.6 (not released. Internal only)
Add support for exporting PCM/TCM backups separately from MultiECU tools.
Add support for exporting PCM/TCM last tune separately from MultECU tools.
Add support for registered Trinity auto CROM notifications both Full and Incremental when available on the Diablosport server.
Cleaned up DSDownloader self update mechinism to use TMP folder instead of current working directory.
Cleaned up strategy for loading custom/canned PCM and TCM tunes and associated ORI files.
Additional verification sending/adding tunes to send to tool that file is valid tune file.
Additional verification when attempting to re-flash device with a damaged CROM file.
Include Vehicle Make, Model and Year in Trinity registration.
2.2.1.5 (not released. Internal only)
fixed saving calid for Ford F150 (not released. Internal only)
2.2.1.4
rebuild for VS20005
2.2.1.1 - Trinity support
2.2.1.0 - Trinity support
2.1.0.9 - Trinity support.
2.1.0.7 - Trinity support.
2.1.0.6 - Trinity support.
1.9.9.0 - Simplified some UI elements for non-CMR users.
1.9.8.9 - Fixed calibration updater for 7135.
1.9.8.8 - Fixed custom tune checksumming error.
- Automated update mechanism.
1.9.8.5 - Support for new GM and Ford 6.4 Predators.
1.9.8.0 - 7151 CROM update timeout.
- Communications protocol default setting incorrect for first time installers.
1.9.7.9 - Fixed version check for 7135 to accommodate major version jump to 9.
1.9.7.7 - Timeout and default compression flag fix for u7151.
- Tweak to text on the Original Backup Warning dialog.
1.9.7.6 - On the calibration update tab, added statement that the predator needs to be on the latest rev before continuing.
- The window focus was on the wrong button for base file selection dialog. It was on Cancel, is now on OK.
- Get tune file dialog has YES NO, added a CANCEL button.
- Added a version check for 7135 and put up a CROM update warning dialog for revisions below r19.
1.9.7.5 - More changes to the communications to fix some issues on slower computers.
- Settings selections dialog per part number on the first tab.
1.9.6.10 - Fixed 7135 issue with sending custom tunes to the Predator that were created on the Predator.
- Added VIN warning for mismatch between base file and tune.
1.9.6.9 - Fixed issue with legacy mode requiring base file with no compression on QBIC tools.
1.9.6.8 - Fixed issue with small diff tune files asking for base file.
- Added warning for tunes that are identical to the original backup.
1.9.6.7 - Fixed botched legacy mode switch.
1.9.6.6 - Added help system.
- Added predator info dialog.
- Some communications tweaks to improve performance.
1.9.6.4 - Fixes a COM port detection issue for double digit ports.
- Added some required Windows DLLs to the install.
1.9.6.3 - Fixes a custom tune base file location issue[/url]
johnc <at> diablosport.com
Re: DS Downloader Installers
johnc wrote:The latest release version of the Downloader is available through the following link(s):
DSDownloader 2.1.0.9 Current Production Release
Release Notes
1.9.6.3 - Fixes a custom tune base file location issue.
Here is the latest 2,2,1,0 if you are having problems withthe web link.
DSDownloader_Installer_2.2.1.0.rar
(2.73 MiB) Downloaded 2920 times
tech@diablosport.com
Locked
