Boost Pressure / Boost Fooler
vrodrex
Post by vrodrex »
I'm getting ready to put gauges in my truck, not sure about a boost gauge (0-??? psi), how high of boost are you all making with the 7130? BTW I have a 2004.5 "600". Also I'm going to do a boost fooler, how much more boost will I see?
Vas@Diablosport
RE: Boost Pressure / Boost Fooler
Post by Vas@Diablosport »
You'll prolly be runnin high 20s with our tune... more with a boost fooler
No, i don't work here.
kw5.9
Post by kw5.9 »
i know mine is differant but with my current set up I can hit 40psi on a hard pull, stock turbo is not very effecient at that psi but it will hit it! Just my 2 cents
Ram 2500 2007.5,5.9ctd,6spd,4X4,predator,puck,Amsoil air filter, AME amsoil, straight pipe turbo back,silencer stolen,quadzilla fooler
ropnjessi
Post by ropnjessi »
I installed a gauge for up to 50#, I will hit 44#'s or so when hitting it hard, but it all depends on your mods, before the TST and other mods, I could only make around 35#'s. The stock turbo is set at around 45#'s I believe. From what I've read anything over that the air is to hot and not as effective, of coarse if you have twins its a different ball game for the boost temp over 45#'s.
03'/305 Dually 4 x 4
Smarty SSR,62/65/13ss, CFM+
