tried to adjust my rev limiter in neutral to 3300 rpmswith no luck why is this?
rev limiter in drive seems to work fine
srt-4 rev limiter in neutral not working?
RE: srt-4 rev limiter in neutral not working?
That isn't something you can set for the SRT-4. The PCM doesn't know when the car is in neutral.
well I just imagined that if the car its 0 mph it will asumes its in neutral and the neutral rev limit will be activaded so you can use it as a 2-step
Re: RE: srt-4 rev limiter in neutral not working?
Nope, it doesn't workroniwan wrote:well I just imagined that if the car its 0 mph it will asumes its in neutral and the neutral rev limit will be activaded so you can use it as a 2-step
RE: Re: RE: srt-4 rev limiter in neutral not working?
That would be something usefull though if it could be done.
