U7194
Dirkdiggler90504
Post by Dirkdiggler90504 »
Mike,
i tried to install that file as a custom tune, I keep getting errors
Any suggestions?
2007 Tahoe 3LT Gibson Exhaust Diablo Predator
getting errors when? when trying to install the tune to the truck, or when trying to import the custom tune into the predator?
did you hook up to the truck and let it make a backup copy of the new original stock tune??
if not, you have to... you can not import a custom tune into the predator if it hasn't saved a copy of the original backup first.
Dirkdiggler90504
i am getting errors when i try to import the custom tune into the predator. Yes i did back up the stock tune first.
CANUCKPREDATOR
Post by CANUCKPREDATOR »
what messages? be specific
Dirkdiggler90504
well according to the software on my PC i do get a message that says the program has been downloaded to the tool successfully. but when i try to use the tool for anything afterwords is says custom tune error 09 or something like that. then after i erase extra tune everything works perfect again
Are you using the LS2 interface or DSDL?
Dirkdiggler90504
Mike,
i am using the LS2
Should i be using the DSDL?
Dirkdiggler90504
here is the exact error im getting
Custom Tune Problem:
zerror
dsd version unknown
Sounds like you are using DSDL??
Did you maybe use an old DSDL to pull the backup file?
Dirkdiggler90504
I have been using the LS2 pc interface. i tried the DSDL last night and no luck.....same thing
So, you used the LS2 interface to export the backup you sent me, and to load it to the Predator?
And it loads to the predator OK?
Dirkdiggler90504
Yes that is correct. a prompt comes up and it says that it was downloaded to the tool successfully
Email me the tune you are loading please, and a copy of the current backup again.
Dirkdiggler90504
Mike,
I emailed it to [email protected]
got em...
