Shell gas with nitrogen.
Someguys300c
RE: Re: RE: Shell gas with nitrogen.
Post by Someguys300c »
well im a little late to the party, with another reply. but my only guess to the nitrogen hype. is that it gives something for contaminants to bond to. creating NOx. which could be better for your engine, but harder on your catalytic converters. but like i said, its simply an educated guess on my part.
QuickRT2SRT
Post by QuickRT2SRT »
Just because you see the same company name on the gas truck that fills the ground tanks at your favorite gas station doesn't necessarily mean that is the actual brand of gasoline you are getting at the pump. I used to work for the corporate office of a well known brand of gas a few years back and found out while there that oil companies don't necessarily have a terminal in all parts of the country where they sell gasoline and to fix this shortcoming they have agreements with other brand name oil companies to use their terminal to load their trucks in those areas... basically they trade off and help each other cover the others gaps in gasoline terminal coverage around the country. Food for thought. Of course if you have logged and have good results from your favorite gas stations fuel then whereever it comes from is consistent from load to load and shouldn't be an issue.
YMMV(literally and figuratively)
2007 TorRed SRT8 Charger
AirRaid SRT8 CAI, Catch Can, 4127 Motorad t'stat
Predator 93 CAI tune
fireman2118
Post by fireman2118 »
I use Chevon 91 out here on the left coast. It seems to work pretty well.
'05 Magnum R/T - 400 rwhp - 385 rwtq
PPP stage 3 heads, Howards cams 219/227 .600/.575 112 +4 , Ported 6.1 intake manifold, 85mm TB, JBA headers & mids, Corsa Sport, Dominator 3000 stall TC, stage II valve body, Getrag 3.91 LSD, BCR coilovers, Eibach sways, BWoody links, Wilwood big brake kit
340DART
Post by 340DART »
Using Exxon 93 here in Houston, seems OK. Wish I could get it w/o 10% ethanol.
07' RAM 5.7, Rg cab, 91oct. tune, CAI, BBK shorty's Magnaflow with true duals, 180 t-stat., 4:10 gear, 4500 lbs w/o driver. U7137X, V9t07d
