tourque managment and removing it.
madmanwithmouse
Post by madmanwithmouse »
With bigger tires you will gain mpg to a point, by lowering the rpms to around 2k or slighty less. However if you do heavy towing then the higher gear ratio will hurt your economy.
2006 Dodge Ram Cummins 3500 Dully, 4x4, Manual trans:
Predator/Puck, Fass 95 Pump, 4" Turbo back Straight pipe, K/N, Quadzilla moniter and boost fooler, Intake baffle delete, Modded airbox
http://www.dieselbombers.com/index.php?referrerid=1849
