adjust the fan settings not working when the a/c is off
i just install a 180 thermostat and i want to know what is the minimum temperature motor i can adjust the fan settings with the dsp
RE: adjust the fan settings
BI8B
The guidlines I have seen posted by DS people is back off fan settings ten degrees. I have others on this forum say back off 23 degrees 203-180 = 23. I have a truck with mechanical cooling fan so I have no real world experience. You can type a subject in the forum and search for a subject, time consuming yes, but I think these guys get tired of answering the same quesitons over and over.
I think they need to post a FAQ and cover the basics.
07' RAM 5.7, Rg cab, 91oct. tune, CAI, BBK shorty's Magnaflow with true duals, 180 t-stat., 4:10 gear, 4500 lbs w/o driver. U7137X, V9t07d
Cooling fan settings
What ever temp your stock T-stat settings are... subtract 180* for the 180* T-stat. Set all your cooling fans at that #. If you set your HS fan too low, you may find that it runs excessively. You should have around 10* difference between the LS and HS fan settings.B18B wrote:ok thank you
I put HS at 190 and LS at 185
It's not unusual to see running temps above 190* from time to time on hot days, especially with the A/C on...or when sitting in traffic.
I have my LS set at 185 and my HS set at 196. Works great. HS fan cycles once in a while but never runs for very long. My average temp is around 185-188.
I got my info from a phone call to DS.
"El Magnifico" 2009 Challenger SRT8 AutoStick, Corsa Sport Catback Exhaust, Trinity 91 Modified Tune, 180 T-stat, Moroso Catch Can, DMH Electronic Cut Outs, ProTorque Billet Stator 3200 RPM High Stall Torque Converter, K&N, BFG 295/40/20w Rear Tires
Re: Cooling fan settings
broadfca wrote:What ever temp your stock T-stat settings are... subtract 180* for the 180* T-stat. Set all your cooling fans at that #. If you set your HS fan too low, you may find that it runs excessively. You should have around 10* difference between the LS and HS fan settings.B18B wrote:OK thank you
OK thank you very appreciate
- fireman2118
RE: Re: Cooling fan settings
LS 185 HS 192
'05 Magnum R/T - 400 rwhp - 385 rwtq
PPP stage 3 heads, Howards cams 219/227 .600/.575 112 +4 , Ported 6.1 intake manifold, 85mm TB, JBA headers & mids, Corsa Sport, Dominator 3000 stall TC, stage II valve body, Getrag 3.91 LSD, BCR coilovers, Eibach sways, BWoody links, Wilwood big brake kit
I run my LS at 188, MS at 194 and HS at 197. The MS does come on once and a while on hot days. The LS you can just about hear it on most of the time.
05 Mag RT AWD
AFE Stg II CAI
Magnaflow C/B
JBA High Flow Cats
Edelbrock Shortys
SLP 25% Underdrive Pulley
Ported Throttle Body
Jet 180 T-stat
Tune by Johan
BT Catch-Can
AFE Stg II CAI
Magnaflow C/B
JBA High Flow Cats
Edelbrock Shortys
Jet 180 T-stat
Tune by Johan
BT Catch-Can
I don't think you have an MS
2006 Magnum SRT8
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
Re: RE: Re: Cooling fan settings
You are correct, no medium fan so set your HS and MS the same.Quick wrote:I don't think you have an MS
Bigsnake
10 Charger SRT8
11 Mustang Shelby GT500
10 Charger SRT8
\\\B18B wrote:my fan go on when the a/c is on at 192
but not when the a/c is off it go at 211
i put all ls 185 and hs 192 a/c on
and i put all ls 185 and hs 192 a/c off
any idea why
Did you set all your parameters correctly ?
Cooling Fans AC off
* High MPH HS Fan On:
High MPH High Speed Fan On when ac is off and above 8mph
* High MPH MS Fan On:
High MPH Medium Speed Fan On when ac is off and above 8mph
* High MPH LS Fan On:
High MPH Low Speed Fan On when ac is off and above 8mph
* Low MPH HS Fan On:
Low MPH High Speed Fan On when ac is off and below 8mph
* Low MPH MS Fan On:
Low MPH Medium Speed Fan On when ac is off and below 8mph
* Low MPH LS Fan On:
Low MPH Low Speed Fan On when ac is off and below 8mph
Cooling Fans AC on
* HS Fan On:
High Speed Fan On when ac is on
* MS Fan On:
Medium Speed Fan On when ac is on
* LS Fan On:
Low Speed Fan On when ac is on
Bigsnake
10 Charger SRT8
10 Charger SRT8
Cooling Fans AC off
Cooling Fans AC on
* HS Fan On:
* MS Fan On:
* LS Fan On:
Cooling Fans AC off
High MPH High Speed Fan On when ac is off and above 8mph = 192f
High MPH Low Speed Fan On when ac is off and above 8mph = 185f
Low MPH High Speed Fan On when ac is off and below 8mph = 192f
Low MPH Low Speed Fan On when ac is off and below 8mph =185f
Cooling Fans AC on
* HS Fan On:
High Speed Fan On when ac is on = 192f
* LS Fan On:
Low Speed Fan On when ac is on =185f
yes to all
I understand that some '05 models do indeed have MS fans! Guy on another forum said he sat there and listened to the speeds change!cleary524 wrote:I run my LS at 188, MS at 194 and HS at 197. The MS does come on once and a while on hot days. The LS you can just about hear it on most of the time.
2006 300C-SRT
185 T-Stat/Catch Can
DiabloToona CMR Gas tune
Extra "Flex" E-85 tune
RE: Re: RE: Re: Cooling fan settings
anybody has an idea why fan does not go when the a/c is off
