29 misfires logged since last cleared?????
I attached the log file. The unit doesn't show any misfires while logging over the 9 minutes on this file. Will someone please tell me why the misfires might possibly showing up? First time I have added this pid, so I have no other history.
07' RAM 5.7, Rg cab, 91oct. tune, CAI, BBK shorty's Magnaflow with true duals, 180 t-stat., 4:10 gear, 4500 lbs w/o driver. U7137X, V9t07d
HemiHorsePower
Re: 29 misfires logged since last cleared?????
what dtc are you getting? Sometimes with a cam upgrade, there's a lot of rumbling going on in the cylinders at idle, or lower rpms and will set off the , i think it's the p0300 code, Random Misfire, which can be adjusted in a CMR to raise the knock sensors to a higher rpms, where the rumbling is not happening.340DART wrote:I attached the log file. The unit doesn't show any misfires while logging over the 9 minutes on this file. Will someone please tell me why the misfires might possibly showing up? First time I have added this pid, so I have no other history.
I don't see a cam in your upgrades though.
HH
06 Ram 1500, LT Headers with Gutted Cats, Spartan Cam, CNC Heads W/ 6.1 Pushrods, CAI, 180*Therm, Magnaflow 40 series, Innovate Wideband, Flex-a-Lite E-Fan, Sharadon Stage 3 Valve Body, APS 2400 Stall T/C, DS U7137.
RE: Re: 29 misfires logged since last cleared?????
Thanks for the reply Hemi,
Stock cam. How can the Pred show 29 misfires and not show any on the trending graph? I would like someone to tell me exactly what triggers misfires and then maybe I can start to understand what might be going on. When I think of a misfire I think of a cylinder that is weak because of a lack of spark or compression.
DS Tech support, please clue me in on what drives these misfires. should I suspect a bad coil pack?
You are looking at misfire history since code cleared. Likely happen rarely due to cold starts or poor fuel.
Thanks Mikel!
