I have a 2001 Camaro SS w/ M6, I just bought a U1798 for.
Two questions:
When I remove the torque management I feel no difference to the car in any way, it still feels like it bogs down/hesitates at lower rpm (cannot spin the tires in first gear from a roll w/ clutch fully engaged). And traction control is off.
Two, when I install the performance tune I get a noticable knock above 5000 rpm. I have reinstalled the factory tune w/ no issues but I was wondering exactly what the performance tune changes (timing, fuel curves, etc.?)
Torque Management
zz4camaro1980
RE: Torque Management
Also, car has a lid and catback exhaust.
Whiterock1
zz4camaro1980
Whiterock1
Leans the air-fuel ratio to make power. LS1s, I had a 2000 WS6 T/A, have good knock sensors, so you shouldn't be getting any knock. I don't think the tune advances timing, but not sure. Can you use the tool to check and see if knock retard is taking place? Otherwise, the Diablo guys will have to step in. 93 Octane should be all you need.
zz4camaro1980
Re: Torque Management
These tunes change the timing and fuel curves.zz4camaro1980 wrote:I have a 2001 Camaro SS w/ M6, I just bought a U1798 for.
Two questions:
I have run this tune in my 99 Z28 with no issues...just be sure you are using quality branded 93 octane fuel.
