New predator application is misssing or corrupt.
oceanickid
Just got a new U7165 for my 2003 6.0. I tried to download the latest downloads and hit download failed. now the machine says the application is missing or corrupt when I boot is up. All is well with the connection as the application starts to download the packets and gets to packet 2 before throwing the failed code. Tripple checked the computer as per the instructions. The port and baud is right... What now? Thanks Todd
Re: New predator application is misssing or corrupt.
Please check to see what the predator boots up as. You will see a % bar with a message at the top. EX. Booting PCM_6_0oceanickid wrote:Just got a new U7165 for my 2003 6.0. I tried to download the latest downloads and hit download failed. now the machine says the application is missing or corrupt when I boot is up. All is well with the connection as the application starts to download the packets and gets to packet 2 before throwing the failed code. Tripple checked the computer as per the instructions. The port and baud is right... What now? Thanks Todd
You should be able to download the latest crom file and be able to download it.
I will try to email you with a crom, load that one in and let me know if you get it back up and running.
Cole Stevens
oceanickid
RE: Re: New predator application is misssing or corrupt.
Yepper! I loaded the crom file you sent and programmed the 60hp in the truck... All went well. Do I need to update the machine with anything? Thanks Todd Also, is there a better tow program when hauling but not towing.... ie, slide in camper with a total vehicle/camper weight of 11,000 lbs.... It's a big slide in camper in the 250 superduty 6.0 2003 Thanks again.....
oceanickid
Oh, by the way, I'm straight piped and K&N cold air intake.........
Re: RE: Re: New predator application is misssing or corrupt.
You should be fine with the Tow Tune installed in your truck. You can tow your normal payload with those tune with no problem.oceanickid wrote:Yepper! I loaded the crom file you sent and programmed the 60hp in the truck... All went well. Do I need to update the machine with anything? Thanks Todd Also, is there a better tow program when hauling but not towing.... ie, slide in camper with a total vehicle/camper weight of 11,000 lbs.... It's a big slide in camper in the 250 superduty 6.0 2003 Thanks again.....
Cole Stevens
