O2 sensor tune out
whitetalt1
O2 sensor tune out
Post by whitetalt1 »
02 Corvette Z06
U7198 v1.03
I have LT headers and have been getting an O2 sensor code (P0138 high voltage bank 1 sensor 2). I currently have the stock tune. I've tried to do some searching and it sounds like I will need to load my predator with a custom tune that "tunes out" the after cat sensors, right? What else will I need to do?
THANKS
CANUCKPREDATOR
RE: O2 sensor tune out
Post by CANUCKPREDATOR »
you will have to post your original tune and the current tune here for the custom tune to be created
whitetalt1
CANUCKPREDATOR wrote:you will have to post your original tune and the current tune here for the custom tune to be created
Right now, I'm unsure if the harness wiring is hosed or if the O2 sensor sim is dead. In either situation, will the tune out still eliminate sensing the rear O2 sensors? I need to pass state inspection, so the sensors will need to read "PASS" during the OBDII testing.
THANKS
you'll need to replace the O2 sim then... cuz if the codes are disabled in the tune, you won't pass...
and that's an OLLLLD revision on that predator... you should consider sending it in to get it updated/upgraded to the newer version... tunes have changed since then, you'll have more adjustable parameters available to you, you'll be able to data log, etc etc.
whitetalt1
Re: RE: O2 sensor tune out
06MonteSS wrote:you'll need to replace the O2 sim then... cuz if the codes are disabled in the tune, you won't pass...
So with the custom tune, specific DTC's are disabled? Would the O2 sensors show up as "NOT READY" at all times?
whitetalt1
RE: Re: RE: O2 sensor tune out
Can you explain what disabling those codes with a custom predator tune will do? I don't understand why the O2 sim needs to operating. THANKS
with the O2 sim operating, there's no reason to disable the codes... so to the pcm, it "appears" as if there's an O2 sensor and it's working correctly...
BUT, if the sim is not working, and you just go in and disable the O2 codes, then the O2 emissions tests that the pcm runs will never be "ready", cuz you've disabled them... they will always be in a "not ready", or "not run", or "incomplete" status...
so, you will never pass emissions tests...
whitetalt1
How do tune shops "tune out" O2 sensors without O2 sims then? I thought the diablosport predator was capable of doing the same
shit, I can "tune out" your rear O2 sensors just like anybody else can... but you're still not going to pass an emissions test with them being "tuned out"...
when you go to your state's emissions testing facility, you will PHAIL.... just like with anybody elses tune...
CANUCKPREDATOR
Old Predators could. EPA says no more.
05Z71
Re: RE: Re: RE: O2 sensor tune out
Post by 05Z71 »
whitetalt1 wrote:How do tune shops "tune out" O2 sensors without O2 sims then? I thought the diablosport predator was capable of doing the same
That is irrelivant. I know of a few "tune shops" that will do your "inspection" also for a small fee. You just have to take it back to them every year and pay that small fee which is normally double what you would normally pay for an inspection.
Makin friends one post at a time!
05 Chevy Z71 5.3L, 18x9 KMC XD Spy Wheels, 275/70R18 Cooper Zeon LTZ, Cherry Bomb Exhaust, K&N Drop in, Predator TWEAKED
MikeyB.
Post by MikeyB. »
I want to know where to get 02 sims for our trucks.
"too many hockey pucks to the head"
