[color=red]my predator does not work[/color]
i need help- i recently bought a diablo predator for my 2003 lincoln navigator (5.4 DOHC v8 32 valve) but when i plug it in, it says that the vahicle is not on file.... on startup the screen does read "gas f series trucks"
what is the solution?
greatly appreciate any help.....
thanks
thanks
RE: [color=red]my predator does not work[/color]
What's the part# of the tuner you have? What is the revision that is currently on your tool? What is the CALID of your vehicle? We will need a little more info here so we can help you with this issue.
Phil Jones
Diablosport Inc.
Tech Support
Please do not PM us for tech support, post up first!!!
Diablosport Inc.
Tech Support
PREDATOR V.9r03
SERIAL: d006785
PART: v7153 fseries
HARDWARE: UNIV_REV2
BUS: SCI CAN
BORN: 01/13/09 4048
CAL_ID: MTAL2B5
SERIAL: d006785
PART: v7153 fseries
HARDWARE: UNIV_REV2
BUS: SCI CAN
BORN: 01/13/09 4048
CAL_ID: MTAL2B5
The above post contains all the details of the predator that i could get; hopefully it will help you provide a solution;
do let me know if you need any further details.
Hmmm...is this a 4 Valve Navigator?
mike, he said he has a 32 valve V8 so yeah he has the 4 valve motor.
yes- it is the 4-valve engine.
thanks.
thanks.
here is the chassis #- 5LM FU2 8R 83L J 15714
JUST IN CASE.
JUST IN CASE.
Sorry, we do not currently have support for the 4 valve Navigator applications.
lazorrazor
we ordered the programmer from summit racing- we called summit racing and made sure that the predator was compatible with the 4-valve navigator; they even called diablosport to doublecheck the same and ensured us that this would work on my car!!
so i dont understand how this could happen?
everything was doublechecked to make sure we had the right part.
