Idle up not working
Idle up not working
I just updated the new u7131-9r03.crom file to my Predator U7131 and the idle up function dose not work. I drive a Dodge 2006, 3500 mega cab 4x4 5.9 diesel with no upgrades yet. Hope some one can help me out with this. I have it tuned to the extreme setting and that seems to work the best but I really don’t want to have any problems down the road. I drive all over the place up here in Canada and would like to get the best mileage and use the idle up feature in the winter.
RE: Idle up not working
Try disabling the idle up, then enable it.
Do i disable it by pluging in the tuner and reloading it with the idle up function off and reloading the tune?
You can do it like this:
Go to the idle up feature, select disable, then cycle the key off/on
Then go back in, enable idle up, and cycle the key off/on again, that should do the trick.
You are the shit. Thanks for the help, I bought my predator two years ago and the engin surge was so bad i never used the thing till the uther day i noticed the web site on the back of the tuner and started reading. Its nice to finde a product out there the helps i guy out, we dont see that kinde of service much up here in Canada. Any Suggestions on what to put in my truck to prevent damage? Thanks agian.
Use the 100 HP economy tune for daily driving.
Can the idle up feature be activated to work after a set number of minutes idling, or just when the outside temp is cold?
When you enable idle up, it is up to you when you turn it on in the truck.
