U7170 02' F250
U7170 02' F250
02' Ford PSD U7170. What program is installed on this predator when you buy it new, I bought this one last week. Also can I calibrate the tire size, because the trans seems to shift into a higher gear prematurely.
RE: U7170 02
Well the tuner has three tunes preloaded, tow, 85hp and extreme tune. You can select which one youd like to put on the truck when you frist plug it in. As far as tire size goes i forget if you can do it with that tool or not but you can give it a try by going to install a tune then hit "modify tune" and see if you can adjust it in there.
Don
2002 WS6
2002 WS6
RE: U7170 02
It does tire size as per adjusting the tranny, but it does not correct the speedo. It changes NOV.
RE: U7170 02
it will help you adjust tire size for the trans shifting issue, but your speedometer will still be off (speedometer reading comes from the separate ABS computer, not the PCM).
