U7193 Logging 05 Avalanche
Iceberg
RE: U7193 Logging 05 Avalanche
Post by Iceberg »
I uploaded the wrong file before. The coreect one is above.
05 Chevy Avalanche 1500 Z71,5.3L, GMPP Performance Cat-Back Exhaust, K&N Dropin Filter, Predator U7193 (Upgraded) Performance Tune
Re: RE: U7193 Logging 05 Avalanche
Iceberg wrote:I can get on a road where I can drive at 75mph for a while. This puts me in the 2000rpm-2200 range. Should I log this way or should I log in 3rd?
yeah, if you can go 70-75 steady so that your rpms are 1800-2200, that works...
and if it's that hot there already man, don't kill yourself... do it with the A/C on, don't worry about it...
sounds like you probably use it most of the time anyway with temps like that... daaaamn!!
RE: Re: RE: U7193 Logging 05 Avalanche
ok, looked at your log....
your average ltft's are at 2.7xx and 3.6xx... so for now, I'd say to go -3% on your injector slope setting... install that modified/adjusted tune setting, put on about 75 miles, and then do a new steady driving/cruising log... and select the appropriate throttle/accelerator pedal position parameter this time around....
then post up the new log and let's have a look at it...
Iceberg
Re: RE: Re: RE: U7193 Logging 05 Avalanche
Post by Iceberg »
06MonteSS wrote:ok, looked at your log....
Thanks! I will keep you posted
Iceberg
new log
Post by Iceberg »
I did another log with the right parameters set. Have not adjusted injector slope yet.
Iceberg
Latest log
Post by Iceberg »
Here is my latest log. I adjusted -2 from my last log and now this one says to adjust another -3. Does this seem right?
05Z71
RE: Latest log
Post by 05Z71 »
Iceberg, what part of Texas are you in bud?
Makin friends one post at a time!
05 Chevy Z71 5.3L, 18x9 KMC XD Spy Wheels, 275/70R18 Cooper Zeon LTZ, Cherry Bomb Exhaust, K&N Drop in, Predator TWEAKED
Iceberg
RE: Latest log
Post by Iceberg »
I am in Austin.
RE: Latest log
checked out your log...
I would go another -2%...
you are saving the change after you adjust the slider, right? adjust it, press the center button to save it, then install the tune with the saved change???
cuz the ltft's are similar to your first log I had checked out... doesn't seem like your previous adjustment took hold...
CANUCKPREDATOR
RE: Latest log
Post by CANUCKPREDATOR »
any differences in the weather between the logs? temp and humidity will effect results.
Iceberg
Re: RE: Latest log
Post by Iceberg »
06MonteSS wrote:checked out your log...
I will make the adjustment this weekend.
Thanks!
