u7194 09 silverado
I logged ltft and got them dialed in, but my afr at wot neede adjustment still. So i adjusted it -4 and -6 like logredux told me to. I took the truck back out and did a wot log and plugged the data in and it told me my ltft's were off 4%. Is this normal? here are my loggs.
wot tuning
when doing a WOT log, you can not check your ltft's.. they will be off, cuz they'll be negative at WOT... with a WOT log, the only thing you want to make sure about the ltft's is that they are 0 or a little negative...
to see if your injector slope is adjusted correctly so that your ltft's are in the 0 to -2 range, you need to do a normal steady driving/cruising log...
what do you have your injector slope set to right now?
